5.0 Manual swap- 2002- Hurdles
b3million
Forum Member
Nowhere
AL - USA
Other
B3000
Drive
Good afternoon, fellas.
I'm pricing out a 5.0 swap for my truck. I want to keep a manual and retain selectable 4wd capability, so I won't be doing the explorer transplant.
I had a few questions about motors, transmissions, and wiring options.
First- I understand that the 302 came with forged pistons for a select number of years until mid-1992. Was this all 302 motors or just the mustang/thunderbird variants?
Second, there's a 40hp difference between the truck 302 and the car 302 of that type of motor. Can that difference be made up with an intake swap and a tuner, or is it more involved?
Third, is there a difference in transmission bolt patterns between the truck blocks with the m5OD and the mustang blocks with the T5?
Fourth, I imagine I get around the PATS stuff by getting an older motor and computer. Am I neglecting anything there?
What I'd like to do (Ideally) is find a 1991/1992 f150 with a manual transfer case that I can grab the motor, mounts, M5OD, and transfer case from, and adapt that into my 2002 b3000. That solves any need for a custom harness/ computer and wiring hassle. Plus, it's a cheap option and reduces the need for pick-and-choose part sourcing.
The problem is the power- I want at least 225 base hp and forged pistons so I can add a supercharger later down the line. That might mean I have to get a foxbody motor and computer, which will be harder and more expensive. I want the M5OD so I don't have to adapt a transfer case to it. Either way the computer will have to come from a mustang or an f150.
There's also the option of the 351W, but i seem to recall hearing somewhere that those motors have fitment issues and never came in manual, so that significantly increases the computer hassle.
Answers/advice appreciated.
This in relation to a multiport EFI SBF roughly 1986+...
Only the HO and I don't remember if it was just only the Mustang or not.
Keep in mind those pistons/rings are 30-40 years old, there is a good chance if they haven't been rebuilt with who knows what... they may need to be.
Cam, heads, pistons, intake, exhaust, tune...
There is some variance, Mustang makes a lot more power than truck but generally they have the same heads. Generic "car" 302 will have different heads. Cam will go a long ways which will require a different distributor and may change your firing order
Cars will have a roller cam, most mid to late 1980's truck blocks are set up for a roller but are still rocking flat tappet.
If you can find one just the engine out of an Explorer is really the best route IMO. As much power as anything, good intake that fits, arguably the best belt drive system Ford hung on a SBF and it is basically set up to fit in your engine bay from the factory. Then do whatever feels right with the electronics and transmission.
Same pattern, use the correct separator plate/starter for whatever transmission you use.
Whatever your truck will need to see from the ECM to function will need dealt with. Mine didn't care, yours will care. I haven't been down that road on a truck that new though.
I have never done this swap, but have researched it some. While the bolt patterns are the same, the truck bellhousing is larger since they use a larger flywheel. They say the car uses a smaller flywheel, so a smaller bellhousing, and it fits better at the firewall of a ranger. Unless you want to use a little bit of a body lift to help clear the larger truck bellhousing.
So if you are going to use a Mazda made for a transfer case, I guess you will have to use the larger bellhousing since it will be from a truck.
They are all shaped different but the bolt pattern is the same.
My C5 bell was deeper than my M5OD bell, it varies from transmission to transmission.
The HO came in the foxbody, the 91-93 cougar/thunderbird, the 87-92 lincoln mk7, as well as the 96+ explorer/ mountaineer. My only issue with the explorer motor is potential computer/antitheft issues and not having forged internals.
Plan is to get the parts and do a rebuild. bearings, rings, and a tune. Cam too if I can find the right one. I definitely want rollers. What do you think the chance of failure is if I grab everything but the engine from a truck, then hook the block up and tune it? Not counting exhaust, I know I need headers for that. I'm mostly worried about the transmission fitting up against the engine and the shifter location.
I figure I keep the original keys and ignition cylinder. That way it's communicating with the truck. I can probably cannibalize the PATS module from the original computer and jury-rig something.
I also want AC. I don't use it much, but, y'know, for the girls.
I know the fox had forged pistons, I don't remember if they bled over into the tbirds ect or not
I know the Explorer's were not forged.
Trans will fit the engine. T-5 puts the shifter farther back than a Ranger transmission. 97+ M5ODR2 puts the shifter in roughly the same spot as a Ranger M5ODR1 but is geared more like a truck transmission.
Will the R2 bolt to the 5.0?
The T5Z can be bought from Modern Driveline with a front-shift, tailhousing that they came up with and it puts the shifter precisely where you need it in the Ranger. You'd have to tell them what year truck as they seem to know what fits and what doesn't. It fit my 87 single cab 2wd perfectly. $3100 delivered.
But you won't be using a T5 due to wanting 4x4.
Avoid women who find a Ranger an enticing vehicle. 🙂
I have burned and learned, my friend. But even the ones who don't usually think "Eye-ball melting Alabama Summertime" is a bit too toasty.
I, for one, think it's nice on the skin.
While we're at it, any cam recommendations? I'm planning to straight pipe the thing for convenience, so nothing with pops or bangs or whatever. I'd like a good bit of chop at idle but nothing that'll come close to stalling.
The f150 transfer case is a TIGHT fit in a ranger, but it can be done. My truck is a 2001 and it really doesn't care that I removed and replaced the ECU with a megasquirt. PATS is inside the ECU, so if you remove it, you also remove PATS. 351W is a taller deck and interferes with the A/C box primarily. If you are planning on forced induction, I would recommend just building the cheapest junkyard engine you can find. 302 parts are dirt cheap and you can get a full balanced rotating assembly with forged pistons for around 1500 dollars.
There are 4x4 T5s out there with the shifter in the correct place (S-10 ones bolting up to NP231 transfer case). But once you pick one with a high enough 1st gear to withstand the torque of the 5.0, not very good for off road.
The M5OD-R2 is probably the best option; pick an older one (300 or 302) with 1/2" bolt holes on bell housing but shifter would be close to dash vs the newer one (4.2) with 12mm bolt holes / shifter closer to that of the M5OD-R1.
The BW4406 transfer case found in '96-03 F-150s/Expeditions is about 2-3/8" narrower than the more common BW1356 which is a very tight fit.
It is super easy to drill out the holes from 12mm to 1/2"
Otherwise 4.2 uses the same bolt pattern.
Use a separator plate from a V8 M5OD though, the starter hole is different. You can enlarge the hole with a dremel but it is a PITA. I didn't know this going in and made the 4.2 plate work but it wasn't much fun.
I have a R2 out of a 2004 F-150 in mine, stock ranger FX4 shifter fits absolutely perfect with a little modification to the stub shaft coming out of the transmission.
You have any pics of the fitment/ modification?
And where would I get a separator plate? That seems like one of those things you could sneak out of a junkyard if you left it bolted to the block you were taking. Either way I'm going with the R2, that way I can just take the transfer case and transmission as one piece.
