5.0 Manual swap- 2002- Hurdles
The f150 transfer case is a TIGHT fit in a ranger, but it can be done. My truck is a 2001 and it really doesn't care that I removed and replaced the ECU with a megasquirt. PATS is inside the ECU, so if you remove it, you also remove PATS.
You have any pics of the tcase fitment? I'm gonna go with the 302 on account of the AC bit, but again, haven't quite figured out the computer.
I have no idea if an explorer harness would even plug up to a truck/foxbody ECU to begin with- if it's a few pin swaps here and there, good deal, but if the plug is completely different, that's a whole nother level of "nuh uh."
Not to mention, the Explorer 302 is coil pack ignition and most of the 302s that had manual options came with distributors (if I interpret the junkyard pictures correctly.) That is obviously not something I want to break by swapping an ecu.
What are my options for dealing with that? (running an explorer motor to keep coil pack ignition and still being able to run a manual)
JY would be best place, most aftermarket ones I have found are set up for the smaller starter.
Here is a write up I did on it awhile ago:
The mod is you basically dremel the starter hole slightly bigger, not much to take a picture of.
You should really look at the differences between the 1356 T case and 4406 T case, if I remember right the offset is like 3" more on the 1356 that would be in a 5L F150 which would put it deeper into the frame rail and below the frame, if you're planning on sticking with the stock axles that could be an issue.
The f150 transfer case is a TIGHT fit in a ranger, but it can be done. My truck is a 2001 and it really doesn't care that I removed and replaced the ECU with a megasquirt. PATS is inside the ECU, so if you remove it, you also remove PATS. 351W is a taller deck and interferes with the A/C box primarily. If you are planning on forced induction, I would recommend just building the cheapest junkyard engine you can find. 302 parts are dirt cheap and you can get a full balanced rotating assembly with forged pistons for around 1500 dollars.
351W being taller deck, is both taller and wider; there is significant interference with HVAC box (even the 5.0 has some), it gets "snug" with the steering column and makes for challenges with exhaust manifolds/headers.
Later 5.0 blocks (80s and newer, as opposed to 302 blocks from 60s) will only make about 450 hp before the integrity of the block comes into question. The Mustang boys would split their blocks in 1/2 when exceeding.
What is your plan down the road for the fuel injection system when you eventually go with a blower or turbo? I am thinking a stock computer is going to need modification to handle any boost. You are hung up on the anti-theft thing but I would look into the future as to what computer is going to be the best for your final boosted engine goal, and possibly plan on that now if it's not too expensive.
Some Explorers/mountaineers came with a 5.0 and a manual transmission but they weren’t really common.
The BW1356 is a huge t-case. Saw a guy just recently that tried fitting one in a Ranger and trying to tuck it up in the frame. After cutting on both the frame and t-case he abandoned the process in favor of a different t-case that fit better. I’m not really a fan of the BW1356 in my F-150.
96/97 Explorers had no PATS but ran the return style fuel system.
98 Explorers had PATS and a return style fuel system.
99-01 Explorers had PATS and a returnless style fuel system.
Megasquirt and other such aftermarket computers may be a worthy option especially with wanting to add boost.
IIRC oddly they were only available in 2wd.
Easiest would be to get a tune made for a manual transmission. They could nix PATS while they are there too.
Explorer is the same 5.0 as anything else. The intake is basically a cast aluminum GT40 intake and is a popular upgrade for Mustang people. The belt system is awesome for a Ranger swap. You will need the oil pan for your truck. If you avoid the later ones with the P heads (if you are not going to aftermarket heads) IMO they are a great base to build off of.
If you don't want coil pack ignition yank the cam position sensor and stab a distributor in it.
They don't have forged pistons but have been beat on for 30-40 years either.
Most blowers I've seen inject into the case/ past the intercooler. Right now I want to get the motor in and running. FI is at least three years down the line if not more, for when I get another truck and this one is just a mud toy. Definitely not keeping the stock ecu for that.
Heard that. Seems like the best of both worlds to just get a distributor. Would that not change the firing order?
I would prefer coil pack ignition frankly, I've done enough distributors to know they're not fun to fix. I could probably just get my tuner of choice to set the PCM up for manual/ flash an older ECU for the newer motor.
28 spline 8.8. Don't plan on exceeding 350 hp right now, but I'm gonna go with whatever tcase requires the least amount of work to hook up to my existing drivetrain. It sounds like whatever is bolted to the back of an M5OD R2 is gonna be it.
I have yet to see a 5.0 manual explorer on a listing.
97 is my target engine year. Might go older if I have to to keep drive by cable. Not sure when or if ford switched off of that.
That being said, if they made them, I can definitely buy a computer and harness for one somewhere.
Edit: I can get a brand new ECU for a manual 5.0 explorer for $80 🤣
If you go with the 4.2L M5OD-R2 route then yes I believe that would be the 4406
If you go with a '99-01 Explorer engine, they use the same fuel system from the tank as your 3L so that would actually be easier than converting to a return system...
use a 208 jeep with a ford input. or a 241 or 231 jeep with 31 spline input.
they fit mo betta
of course...ya know...a 5.3 or 6.0 would be a better idea too.
What's the % chance of failure if I just buy a '97 ecu and hook it to a '01 engine and call it a day?
they fit mo betta
fit on the back of a ford transmission?
i want to keep costs low right now. i get that an ls is a better motor and what have you but the price of getting everything adapted and finding a good transmission is higher than it would cost to get a 5.0, rebuild it, and drop it straight in.
besides if i decide I don't like a 5.0 I can always take it out later and swap an ls in.
Upcoming TRS Events
