Cooling system maintenance & upgrades
MISWFL
Forum Member
Florida
I've got a 1990 XLT that's been sitting for approximately 15 years. Truck has factory A/C. I plan on replacing all the; belts, coolant hoses, radiator, thermostat, water pump and flush or replace the heater core. I might convert to an electric cooling fan as well, if that's possible. I usually get my parts from Rock Auto. I try to avoid water pumps with plastic impellers.
Is there a larger radiator that will fit? I might go with an all aluminum one instead of an OE style plastic tank version. I think I'll run a 180 degree thermostat.
If the A/C is dead and not just from a compressor shaft seal, which is usually an O ring in a spring loaded graphite holder, I'll convert to a more modern smaller compressor. Maybe even a better condenser as well.
The 4.0 automatic has the biggest stock rad. It’s been discussed on here a bunch of times.
Electric fan is possible. I’ve been starting to experiment with it and results are kind of mixed so far. I’m not exactly sure yet if my fan is just weak or if there’s other issues. It all kind of works so I have been messing with other projects but I do need to re-visit it at some point.
I’m running an all aluminum rad on the Choptop as well as the electric fan. I got both together from a member who was out west and not satisfied with the cooling. It’s working here, and I haven’t overheated, but the fan never shuts off once it kicks on.
I’ve done the 180* t-stat in every 2.9 I’ve owned. Unfortunately I’ve also learned that you need to test new thermostats in hot water with a thermometer. I put a new “quality” 180* t-stat in my green Ranger and couldn’t figure out why it never wanted to warm up. Finally put a temp gun to it and found the t-stat was opening at 167*
I’ve had the AC pumps fail at the case half split. Theoretically you could take it apart and fix the seal but I’ve never done that yet. Usually I end up finding a junkyard one that holds or just buy a reman/new. Remember to save the fittings that connect the lines to the pump if you replace your pump.
Mercedes c230 Kompressor pusher fans are a direct bolt in on a first / second gen ranger. @85_Ranger4x4 and i both have them. They're the ones in front of the intercooler and rad on the benz. Strip the plastic off of them and direct bolt to core support hole. I used them as aux fans, but never had to turn them on. The windmills at highway speeds was enough for my electric to never kick on.
My experimenting with cooling led me to a single row rad with puller and pusher fans. I had the best results with less rad and more wind.
Big wind + less rows to move wind thru led to a very efficient system.
Always use an in line thermostat housing, and always put it in the LOWER rad hose, not upper. American Volt thermostat sensors are best ones.
I also have a low profile flexfan on the engine side but I have a 5.0. Even with A/C it works.
I wasn't thrilled with heater/defrost performance with a 180 stat. Air was just kind of lukewarm, depending on where you are that may not be an issue though.
What region or state are you in?
What's the core thickness of your all aluminum radiator? Are you running a thin Flex A Lite type puller fan? I have one on my Datsun that was converted to electric fan before I got it. I'm not impressed at all with them. I believe OE style fans are far better.
On my tuned water cooled VWs, I always ran the later model higher wattage dual speed 6 blade ( vs 4 ) fans, with the later 2 stage fan switches. Summers are getting hotter it seems and A/C puts a big load on the cooling system.
Is that pic the c230 fans? If so, what year are they from? They look different than the ones on RA. 7 blades vs 8 and much longer fan motors.
Yeah, early 00's. These are factory Mercedes, aftermarket may be slightly different.
Not today, CIA.
Lol
Does it get hot enough to need A/C when driving for most people vs rolling the windows down?
Is your lower radiator hose temp switch housing plastic. I looked on their website and it looks plastic to me.
Oh this is all aftermarket stuff.
Theyre aluminum. Pick Amazon alphabet flavor.
My all aluminum rad looks just like the 4.0 automatic rads with the plastic tank and the fan was whatever came with the rad. I went with it partly because it’s what I had and with my body lift a stock shroud doesn’t fit right and I don’t know what ever happened to my stock shrouds so here we are. I’ll probably make some changes to the fan at some point but I’m trying to deal with other projects for a bit
