- Sep 19, 2025
- Bozeman
- State - Country
- MT - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0L
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 32/10.5R16
I noticed that my truck ('93, 4.0 OHV, manual) didn't really want to come up to temperature, figured it must be that the thermostat is stuck open. Got a new thermostat and coolant and went to drain the system. I opened the drain valve on the radiator and nothing came out (yes, I did remember to open the radiator cap to let air in). Turns out there is so much sludge at the bottom of the radiator that it won't drain, even after spending an hour removing the 3 tablespoons of sludge that could be reached with a dental pick and the end of a broken ziptie. The previous owner claimed to have replaced the radiator, and I believe this as the fan shroud is missing, but the replacement may have come from an equally abused junkyard Ranger. The engine overheats when it's hot out or when the AC is on, which I though was due to the lack of fan shroud, but is probably the clogged radiator in hindsight.
It seems based on this that a coolant system flush is in order, as I suspect the engine's coolant passages are almost as bad. Where (if there is one) is the drain plug on the block on a 4.0 OHV, and what procedures/products have you guys had the best results with getting the gunk out?
