06 Frame Repairs
If anyone is in the area and needs cab parts or interior parts, I'll let you at it. Just toss me a few bucks. I'm in north central PA, near Mansfield. DM me for meetup.
I am keeping:
Axles
Transfer case
Driveshaft
Wheels
Passenger door
Door strikers
Radiator
Condenser
Hood
The rest can freely be taken. The husk is going back to the original owner to be scrapped.
Never thought I would, but I found my old account, wooo. I'll continue with this account now.
This is the real reason southerners hate the north...
As a southerner... No, it definitely isn't, but it doesn't help. It does make for cheap part/donor vehicles though.
I got the bed and the u bolts off the parts truck, as well as the shocks and driveshaft. Unfortunately the 3.73 rear in the parts truck has the same rust damage as the 4.10, however it's only rusted down 1/32, vs the 5/32 on the 4.10.
Is it rusted away, or is that just where those axles neck down. The tubes aren't the same diameter the whole width, they get smaller inboard of the axle perches IIRC.
Do yourself a favor and oil that frame every couple years. Stay away from most of the paints. POR15 might be alright but anything else is a moisture trap. I've learned this the hard way long term. I now use Crown Oil on all of my Rangers and the new to me Jeep.
Gotta say though, with that wood floor and pieced together shed, I like yer style bud.
My clapped out garage is getting there. That's a solid $80 hobofreight tarp, because my roof was a colander lol.
I dub this garage "The Shanty House".
06 Frame Repairs
It's actually rusted down. That's where the sticker was. I removed a ton of rust to inspect it.
My parts axle isn't much better, but definitely has more tube wall left. At least enough to where I call it safe for highway and light towing. (I had a senior mechanical engineer look at it for me too).
I was thinking about it. But I'm going down to bare metal and treating with rust converter, then hitting it with a heavy black paint.
I will absolutely be doing yearly frame oil jobs, but I live 30min from the NY border. They use heavy salt on the roads. Luckily here in PA we use primarily calcium, but that has its own issues.
Thankfully rangers use c channel frames and not tube frames lol.
And thanks! I like the garage, not love. I'm pouring a concrete pad this year for a real garage next year. This is a temp setup, but nicer than anything else I've ever had.
Removed the gas tank, rear strap is messed up. Prob just going to weld it and reinstall.
06 Frame Repairs
I just got a Chief needle scaler from hobo freight, replacing my $40 cheapo from Advanced Auto that spilled its guts.
Heres a before condition.
06 Frame Repairs
After 5min of work, my old one would have taken 30min to do this. No rust holes, nice and thick metal too
06 Frame Repairs
Due to the condition of the bottom of my crossmember, I purchased a new one lol.
Unfortunately it'll be a week before it gets here, cost me a solid $118 after shipping from eBay. Also cheap shackles/mounts (cheaper to buy with mounts too for some weird reason).
I really like the air chisel I got. It's cheaper, but is a game changer for removing frame rivets. Between a cutoff wheel and air chisel, it's a cinch.
Too humid outside.....
06 Frame Repairs
Frame cleaning is going well, that needle scaler works wonders.
06 Frame Repairs
6/8 rivers removed from the crossmember. Using a grinder while on your back sucks....
06 Frame Repairs
Modified and mocked up sleeve, still need to fix 2 of the holes, this is for an older frame design, so the holes are slightly off.
06 Frame Repairs
Is it galvanized? Be careful not to breath the fumes if so, very poisonous.
By all means, I deeply inhale over every weld, can't waste the good metallic taste.
It's a painted steel sleeve. I removed all of the paint/coating on both parts where I'm welding, fluxcore sucks as is, so every advantage helps lol.
