Help needed to diagnose an electrical problem
Th1s_0ld_Truck
Forum Member
💻 TRS Socials
Louisville
KY - USA
Vehicle
Drive
I have a 1999 Ranger XLT V6 3.0L, 4R44E with only 128,000 miles. Bought in 2001, as 2nd owner, half of the miles are mine.
On a 3 mile trip to the grocery the engine began to buck slightly, and generally run rough. By the time I reached the store the engine was racing slightly. I turned it off and went into the store. When I came out it would not start. Once I found and replaced a blown fuel pump fuse it started and the check engine light was on. It ran rough driving back home. Once I reached my street I let off the accelerator and it began to buck again. Once home and the groceries put away, I went back out and the truck started right up. The idle was a bit rough but acceleration seemed smooth. I plugged in my ODBII code scanner and found a DTC P0118 code, engine coolant temp sensor.
I replaced the coolant temp sensor and the fuel filter. I checked and found no codes and when started, the truck seemed to run normally. During a slow spin around the neighborhood the O/D light started blinking. Pressing the button had no effect. It took longer than normal to shift into second gear and when it did it shifted hard. Realizing there was still an issue I stopped, turned around and headed back home. The O/D light by now had gone out and it wouldn't shift out of first gear. Acceleration seemed to cause slippage rather than shifting so I let it idle back home. Checking for additional codes, this time I found a P0500, variable speed sensor.
Once I replaced the VSS on the differential the code disappeared. I again went for a test run. The O/D light was not blinking and the truck would not shift out of first gear. Starting in 1st and manually shifting to 2nd works but when I shift to 3rd I get nothing, like putting it in neutral.
I took it to a nearby shop who kept it overnight. They called the next day and said to come get it, diagnosing electrical and transmission issues, neither of which they were willing to work on. I suspect the problem is electrical, due to a short, possibly in the steering column because for quite some time the wipers have come on occasionally when turning the steering wheel in either direction, or when using the turn signal in either direction. They always stop after a wipe or two, and they've always worked when I needed them so I ignored it for a bit. Once I replaced the multi-function switch, the issue remained.
Also for a while there has been a pre-existing parasitic drain. If the truck sits for more than a week or two the battery will be dead. I have been disconnecting the negative battery cable when I return home from any trip. I'll be attempting to diagnose with a meter once I resolve this more pressing issue.
The current symptoms are:
Transmission doesn't shift.
Speedometer doesn't work.
The emergency flashers work but the turn signals don't.
Switching the turn signal in either direction instead activates the wipers.
On starting, the O/D light will occasionally blink. When it does, the transmission will shift, no blinking, no shifting.
As far as I can tell everything else is working normally. I have tried to solve this myself as I'm a senior and my financial situation is less than ideal. I enjoy problem solving, but I'm out of my depth and need some guidance on how to track down this short, or alternatively what else it might be. Today I began wondering if it might be worthwhile to pull the multi-function switch to see if it makes a difference.
In case it isn't obvious I am not driving the truck except for testing. I apologize for the post length but it seemed pertinent to include as much info as possible.
TL;DR:
1999 Ranger XLT 3.0L 4R44E
Turn signals don't work but flashers do
Switching the turn signal left or right activates the wipers
O/D light will occasionally blink. If blinking, the transmission shifts. No blinking light, no shifting
Wow. This one may take some serious thinking. You may have more than one issue.
When you replaced the multifunctiin switch, was the nnew one an exact replacement for your year model?
The OD light, when it blinks, should be giving a code. So try to note the blink pattern.
Hoping a few others here will get involved on this one, especially our special voodoo Dr.
The multifunction was a Dorman 2330857 which according Dorman's web site is an exact replacement. I bought it from Amazon but I have come to be suspicious of counterfeit items shipping from there. As far as the O/D light it is just an on/off alternating pattern at about 1 second intervals and it only happens every now and then. I drove around the block this morning to check the condition. O/D light is not blinking, therefore transmission is not shifting. When beginning to drive it launches regardless if I start in D or 1st.
There is an electrical connector on the transmission that I believe also supply's a speed signal. I'd check for corrosion there. The speedometer could also just have a bad connection to the flexible circuit board on the back of the cluster.
This is why my tach stopped working. All the gages plug into these spring clips that connect to the flexible circuit board.
  • Help needed to diagnose an electrical problem
Thanks for the reply. Sorry for the delay but I have been dealing with another issue. I slipped in the shower the other day and snapped the plastic hot water cartridge/faucet at the wall. Also the incident this post relates to actually happened last August so I've been stuck at home since then and have sort of gotten used to it. The WD-40 specialist contact cleaner arrived today so I crawled under the truck and snapped some photos, the best which I have attached. So before I go disconnecting things are these the connections you suggest I disconnect and clean? Thanks very much.
It wouldn't hurt to clean those. But the speed sensor is toward the rear of the transmission, most likely in the driver side on the tailhousing.
I pulled the black plug loose and sprayed both the plug and the device. The blue one doesn't attach in any typical way that I have seen so I was a bit concerned about disconnecting that one. I could probably get a better look by putting it up on ramps. I've replaced the variable speed sensor on top of the differential. Are there more than one? Thanks.
There may not be one in that transmission. If it had one, it would be in the area shown below so that it could read output shaft speed.
This is a different transmission. Just showing where tje speed sensor would be if yours had one.
Mine has a similar stamped but uncut spot as well. Mine is on the differential. When the first replacement didn't result in a cure, a local mechanic suggested that maybe the new one was bad so I replaced it again with the same result.
I wasn't sure if I should update the OP or reply so I chose the latter. I have been tending to another issue and was only able to get back to the truck over the weekend. The first continuity test from the vss dongle to the gem failed. Assuming an issue with the wiring I tried following the vss wire forward but it tucks up into the frame and I can't get my hand up in there. Tracing forward I found a two block junction located approximately beneath the driver's seat. Disconnecting and spraying well with contact cleaner, I allowed time to dry. I identified the two vss wires by color at this location. I disconnected the dongle from the vss, connected the two terminals together and took a continuity reading at the junction mentioned above. Having success here, I then connected those two terminals together and checked continuity at the gem, again having success. Reconnecting the vss I now have continuity at the gem. Apparently it was my first connection of the two vss dongle wires together and not a fault in the wire itself. Hoping, but not expecting the problem solved simply by disconnecting, spraying, cleaning and reassembling, I went for a drive around the block. The problem remains. It will not shift out of first gear, speedo not working, etc. So am I looking at replacing the gem or is there something else to try first? The weather will be favorable here for a day or two and I hope to get this solved. Thanks for your assistance, All the best.
