Shakey idle and sluggish take off
Wires, rotor and and coil are done. I noticed on start up and high idle, the computer was hunting the rpms a little. Maybe relearning with the new coil? It eventually smoothed out. Idling a little smoother. But still has a stumble. Will do the fuel filter later today or tomorrow and go grab some premium gas and put the treatment in. I scanned it to see if throttle body code has stayed away and it has this far. Here is a link to a vid I took you can see the stumble when I gave a little it and when it idles down.
Have you checked for vacuum leaks?
My idle takes a couple weeks to settle down after I pull the battery cable. YMMV.
The tps sensor on a 2.9 has an eccentric on the bottom bolt. You move it in and out for your "calibration"
You're showing some signs of ecm capacitor failure, but don't let me lead you down the wrong path.
If it turns out to be. It will be the second time I've replaced the ECM in the 17 years I've owned this truck. When I first got this truck it always showed two codes. Egr stuck open when it wasn't and another EGR related error. Truck ran fine until one day it lost all power, would barely move and was running so rich I could smoke out the neighborhood. After lots of trouble shooting I ordered this OEM ECM from eBay and fix all issues. So it could be this one is just slowly starting its demise.
Does anyone know how to test the MAP sensor? I unplugged it while idling and it did surge on the idle a little but, I noticed when I blipped the throttle, it didn't fall flat on its face and when returning to idle is also didn't stumble as much. Could smell it went to the rich side when I unplugged it.
Also definitely got a leaky injector somewhere. When I went to bleed the pressure off to do the fuel filter. There was little to not pressure in the line.
Edit: Map seems fine. I did the ole suck on the line and see if engine responds test. My multi meter doesn't read hz so it the best I can do.
Unless I'm missing something in those photos, that cap and rotor doesn't look much worse than what I usually pull off mine when I finally get around to changing it, and electrical misses haven't been a problem for me. The bad plug wire sounds like it could have been an issue. Still, one bad plug wire would not explain 3 fouled plugs.
If you've been running fuel system cleaner regularly you may not have dirty injectors, but if you're a DIY'er this is worth knowing about. If everything electrical checks out okay but you still have cylinders running rich and lean, this may be worth doing. You'll find YouTube videos showing different versions of this process. You hold the injector open using a 9v battery and test leads. 12v will damage the injectors. Then using something like a syringe you force cleaner through them. First you can test if they don't close completely by leaving the battery off. Catch what sprays out the pintel end so you can see if it's dirty and see when the cleaner flows through clear. I've used throttle body cleaner because it's better around electrical components than carb cleaner, but you'll see videos with people using carb cleaner. A couple of years ago you could get a kit with new screens, pintel caps and o-rings for about $25. The Injector Shop has an EBay store.
@89longbed
Is this the kit your referring to?
Thinking I will give it shot, it will be a chance to learn something new. Also, it will allow me to see which ones are good or bad and see if that coincides with the cylinders that had the fouled / lean plugs and if one or two don't clean up I can buy just that one or two.
I like how that kit has the plenum to intake manifold gaskets and several others, but I don’t see new screens for the injectors. You usually remove them before cleaning using a sheet metal or wood screw, so they’re not reusable. I’ll send you the Injector Shop links Thursday.
Here's a link to what The Injector Shop has for your Ranger. I don't have any info about whether their products or prices are better than anyone elses, but I like the fact that they do injector cleaning and flow testing in addition to selling parts. Read the write-up on the kit. They now do free shipping on the rebuild kits. I think I initially learned about them from a YouTube video they posted. I looked for the micro filters on the Rock Auto page and couldn't find them. Plenum gaskets are $5-15 from Rock Auto.
If it's your injectors that are causing the fuel manifold to lose pressure, they probably need a cleaning. My truck started up like when it was new and ran better after doing this.
Thanks I ordered the kit and it's ETA is the 1st. If I got time this weekend I'll start the process of pulling stuff apart. I also managed to come across some expensive felpro blue gaskets for 30 bucks so I grabbed those as well. May as well do the permanent fix to the leaky valve covers while I have the top of the engine off. Also I read that the lower intake manifold has been known to loosen and cause a massive vacuum leak. Will check to make sure those bolts are still to spec in case that is a vacuum leak that I did not think of.
If the injectors aren't the issue, I can only believe this will help improve the situation. They are pushing 40 years old at this point. Only other thing at this point would be a faulty check valve in the pump for the pressure, but that shouldn't effect the engine running.
Replace fpr if you can find it. They're a weak point.
So, I'm in the tear down to getting the injectors out and came across something I don't think should be. When removing the upper intake, there was oil where the upper and lower intake manifold meet. I'm sure that is not normal. The valve cover are leaking but no way this is from that. Is this normal on these 2.9s for oil to seep right here? May from pcv valve? Definably smell gas in the lower intake.
Pic for reference. And yes there was a gasket there.
Probably a vacuum leak with this as well.....
Also, I got two injectors that do not match the OEM ones. Different spray ends and all. I think these were put in by a mechanic that I had so a head gasket job about 10 years ago. I wonder if they are the same flow rate and if not is also adding to issues.
EDIT: I think those two aftermarket injectors are the issue. They spray a sold powerful stream vs a more mist like stream like the factory one.
Edit again.... The two aftermarket one are rated 19ibls according to the Google search I did on the part number stamped on the side.
  • Shakey idle and sluggish take off
I would ignore the oil issue for now, except checking if your Pcv is working right. Hopefully you're going to fix why the oil is on those surfaces.
If your mechanic didn’t charge you for two fuel injectors I would go back and ask if he found and kept your injectors. Can’t tell if those are okay or a problem, but a matched set is always best. I’ve read of some people harvesting injectors from the junk yard, so maybe there are people here that will sell you two. At least you now know about the mismatch and the fuel in the intake.
I would ignore the oil issue for now, except checking if your Pcv is working right. Hopefully your going to fix why the oil is on those surfaces.
If your mechanic didn’t charge you for two fuel injectors I would go back and ask if he found and kept your injectors. Can’t tell if those are okay or a problem, but a matched set is always best. I’ve read of some people harvesting injections from the junk yard, so maybe there are people here that will sell you two. At least you now know about the mismatch and the fuel in the intake.
Othen then the pcv, I don't know why oil would be there. The valve covers are leaking bad and the gasket will be replaced while this is evolving but I don't think the cover leak can reach this high on the intake.
I think the mismatch in the spray pattern is the main issue with those new ones. And they corresponded to the fouled plugs for sure.
That mechanic was 10 years ago and I lived in California at the time. Now I'm out in Texas. So I'll try to source some factory ones some how or good reman ones and test them before installing.
I gotta thank you, the cleaning went well and I wouldnt have found this without your input.
