1999 3.0L Vulcan Injector types?
Gaston
OR - USA
Other
2001 F250 SuperDuty, 1970 F350, 1972 F350, Aircooled VW
Vehicle
Drive
stock
Enjoying my lawful pursuit of happiness.
Hey Howdy,
I have a 1999 3.0L Ranger with the V code in the VIN. I am thinking this is the Flex code. Among many fixes I bought injectors from FleaBay that looking back at the purchase - I am thinking they are gas injectors.
Idles rough, crap acceleration when cold, long term trims are 25, I have battery drained the PCM several times. I have Lean codes both banks. Given that you name it, I have checked it or fixed it....Do I just need to change to Flex injectors? It is not clear to me when I look at OEM sites for parts which injectors are which. I got some 'OEM PN' from RockAuto, but they do not match with the Ford OEM part sites.
Injector recommendations? I do not want to pay $60ea.
Thanks!
Nick
I picked up this POS in the fall last year. Just for background many things fixed:
-Plugs & Coil
-Upper and lower intake gaskets
-Was three different types of injectors - replaced
-All possible Vacuum leak stuff:
-PCV and hose, EGR Check, Evap hose,
-Brake booster (was bad)
-MAS, IAC, Intake plenum, O2
Also, I looked in the case of the PCU and nothing burned or broken.
Did your fleabay injectors come from a company with an easily recognizable name that also has a reputation for making quality parts like Bosch, denso, delphi.. orrrrrr was the manufacturer name closer to MeiSoHuard or TuTuPupu?
Are you running "regular" fuel from the pump (e10/15) or are you actually running "flex fuel"?
What's your scanner say your injector duty cycle is while going WOT down the road?
Injectors aren't something to cheap out on. If "real" injectors cost 60 bucks... Well... Then that's just the cost of repair 🤷🏻‍♀️.
LOL - Thanks for the reply.
Regular gas e10 I believe.
I will check the scanner (What's your scanner say your injector duty cycle is while going WOT down the road?)
Any thoughts on the dif in injectors? I do assume that they are cheep, but functional.
Thanks again.
More like Harduwish!
Thanks again.
Well.. my ranger doesn't currently run lol so I couldn't say what I'm looking at for duty cycle BUT.. there's no way I'd be running 10$ a piece eBay injectors in.. well.. anything lol.
I found a set of reman'd DENSO injectors, flex fuel, from a seller called BIG DAWG DIESEL AND SURPLUS (eBay).. currently 190$ with a coupon code.. free shipping. Yeah.. way more than 60 bucks but... They're from a brand that anyone can have confidence in..
I still don't think injectors are causing your lean codes though. Just out of curiosity.. what brand are your o2s? Cheap o2's are generally garbage.. and Ford's reeeeally appreciate having motorcraft (or equivalent) sensors in them. I *believe* NTK was still Ford's choice of manufacturer to make their o2s when your truck was made.. so those would ideally be the ones to have in it.
I wouldn’t hesitate to use Bosch o2 sensors either, but there’s also a lot of fakes on the market so make sure who you buy from and on Amazon watch for the “fulfilled by Amazon” tag because that’s resulted in a random mix of legit and fakes… What a frickin world this is that the market is flooded with counterfeits and fakes of auto parts… but that’s another story…
Hello again,
Blmpkn,
Back to the duty cycle question above:
WOT = 100%
Cruse at 55mph = 50-70%
Idle at stop light = 30%+
What does this tell me? If the computer thinks it is driving a larger injector for e15, are these value too high?
O2 sensors are Bosh
Thanks,
Nick
Hello again,
Blmpkn,
WOT = 100%
O2 sensors are Bosh
Thanks,
Nick
Whelp, seems as if my assumptions about your injectors & lean codes were probably wrong 🤷🏻‍♀️.
100% duty cycle at WOT absolutely tells a guy that the injectors don't flow enough.. so.. don't be doing any more WOT lol.
However, it's still a head scratcher to me as to WHY they're running way too hard considering your using "regular" gas. It seems like non-flex 3.0s have 15lb/hr injectors.. flex code injectors are around 20lb/hr.
Who made the injectors that you currently have in the truck, and what's the manufacturers part #?
If you delete the lean codes and go for a regular drive like Grandpa (no where near WOT) do the lean codes come back?
Thanks Blmpkn,
The injectors are the ones I showed above. Very cheap. I always drive like a grampa...am one! LOL
But, Yes I have reset the codes and the check engine light comes on quickly. The truck runs rough at idle while cold. If I battery drain the PCM, then it takes a few drives before the trims max out again.
I may invest in another cheap set, but this time Flex injectors.
NIck
Wouldn't they end up running more duty cycle if they are regular (15lb) injectors and the computer expects flex fuel (20lb) injectors? I mean the O2 would have to show lean first then the duty cycle goes up and the PCM tries to fix the lean condition. Interesting that it goes all the way to 100%. I thought the PCM only went to like 85%...
That's whats got me scratching my head.. he's running regular fuel, so 15lb squirters SHOULD be more than adequate.. in theory.
I don't think the computer really 'expects' to have a specific size injector per say.. but it DOES expect the upstream o2 to be relaying a target AFR. So if he WAS running e50+.. there's no way they'd be able to flow enough to stay in said target AFR and it would naturally pop up a lean code.. but with regular gas.. the math says they flow enough.. they do for non-flex trucks so 🤷🏻‍♀️ idk what the difference would be.
Where's Ron when you need him? 😑 I miss our resident AI.
