Orange 1977 Pinto
Yes I know. But they couldn't find ANYTHING to do with a sending unit, including individual pieces. But I was able to solder the float and there is no bubbles showing when immersed in water. I have the sending unit submersed in vinegar to get rid of the rust. I ohmed the gauge sender and its working, so that's good news too. The sock I think I can find a generic one that will work. Only maybe problem is the square o-ring gasket. The old one is swollen too big to use again.
For that use, I wouldn't worry about if it's square. I've used a vacuum belt before.
McMaster is great for oddball o-rings
not the cheapest but the best source
If it's swollen, cut it down short and super glue it back together, it's how custom O rings are made...
I've soldered a float before for my F350, front tank always read empty and found it had a hole rubbed in it, don't remember details but I fixed it, was kinda a pain with the pressure inside...
My local autoparts store come thru for me and found an o-ring. He called it a quad-ring, probably named for the four sides. An outrageous price of $1.47... The new one is the thicker one.
Orange 1977 Pinto
Orange 1977 Pinto
The part #qr-229 is the one to use if you need an o-ring for a pinto.
Also played with cleaning the sock. Started out with the StarTron tank cleaner I bought originally. It did absolutely nothing. Then soaked it in xylene and that did ok. Softened up some goop inside which I carefully scraped out with a dull dental pick. Finishing off with an overnight soak in Spray Nine, which surprised me by discoloring by about the same amount as the xylene did. Which is good. I'm feeling fairly confident I can reuse the sock.
Next will be an inspection of the tank. Then decide if I'm dropping it. I think it will be fairly easy to drop too.
@Rick W
I picked up tall jack-stands to use under my car lift. Home made but good workmanship. Paid $50 for the pair. I couldn't buy the material for that price... I'll need to weld feet to the bottom once I confirm the height is correct. There is about 6" of height adjustment on the screw-jack at the top.
They look super tall in that photo.
I'll run out and measure. They barely fit into my Ford escape...
69.25" and 76"
Just over 6" of adjustment.
Orange 1977 Pinto
Orange 1977 Pinto
I finally recieved my front rotors with a 5 x 4.5" stud pattern. ~$450 delivered includes seals and bearings. I have a ranger rear to put in and that gives me the same pattern on front and back. Plus a bit deeper gearing at 3.00 or 3.73 or 4.10 or 5.13... Choices... Lol.
Orange 1977 Pinto
Orange 1977 Pinto
Orange 1977 Pinto
Its the same size 9.25" rotor so I should be able to reuse my calipers.
I think 4.10 in this with some relatively short (compared to Rangers) tires would make for fun. Though 5.13 would be a riot around town.
Was going to drop the tank and noticed the fuel inlet grommet was cracked.
I can't find one locally and online is nearly $50. Nope, not paying that much. So I bought some fuel safe caulk. $15. And I can use it elsewhere.
Motoseal is not a caulk. Not even what most think of as gasket maker. It never "cures". It'll be just as wet and sticky years later as it is in the package.
That's what I'm looking for. Thanks for confirming.
Well, I found a grommet that should fit. There was 2 left in stock so I bought both. About the same price as the caulk, which I'll probably return.
Orange 1977 Pinto
