What did you do to your 2019 and up Ranger today?
Guys,
I'm about to change the fluid in my Transfer Case. Do I need any special "spout" or pump to get the new fluid in?
CMOS
Guys,
CMOS
No, they didn't mess that one up yet.
Guys,
CMOS
It’s easy
I just put the SCT X4 with custom tunes from Revolution Automotive. I did a quick test this evening. They said not get into to hard till the transmission has some time relearn. The tune has definitely woken the Ranger up and I haven’t even really tested it yet.
So here are my 1st drive thoughts about the Revolution Automotive tune in the Ranger. WOW what a difference. So much so that I am having to relearn how the truck drives. Everything I’ve read about the tune people say it wakes the truck up. It most certainly does. The gas peddle is more responsive. Before the tune the turbo lag was definitely felt. Now I can’t even feel the lag. The tune is worth it just for the improved shifting. It no longer skips gears. I have not really gotten in the throttle yet, but the power increase is awesome. This tune is legit.
Guys,
I use an $8 transfer pump from Harbor Freight. Cut the hoses in half, the way it comes they're way too long.
You will need a 10mm (I think) hex drive to get the plugs out. The case is aluminum so don't crank them real tight, the torque spec is like 18 ft. lb.
I used Redline D6 ATF in the transfer case both times. It meets the Ford spec in the owner's manual. Amazon or Advance Auto carry it.
Truck is still in the body shop. About a week longer than they originally told me. I called today, there is a chance they will have it done tomorrow. Among other things, the intercooler was damaged and the first one they got was damaged in shipping so they had to order another one.
I changed out the spark plugs this morning and was wondering what people thought about the plugs I pulled out of the Ranger. 88,000 miles. Changed the plugs out to support the tune. The tune is incredible. Love how the truck drives now that I have driven it for a few days now.
  • What did you do to your 2019 and up Ranger today?
View attachment 141362View attachment 141363View attachment 141364View attachment 141368
Also, 1 and 2 were very difficult get out. I thought I was going to break 1. 2 would move a little and stop move a little stop. 3 and 4 were easy.
Same plugs I got. My old ones weren't that black though. Do you do a lot of short trips?
It may have been but it’s previous owners. But not with me.
Those look VERY black to me. Weird that it seems to be in the threads so much too...
I don't like how dark those plugs are. Odd that #1 and #2 were the hard ones to pull out. Usually, it's be back two, especially if you have a cowl leak onto the spark plugs, like some have had with the 2019-2023 models. Hopefully, things will be better with the next change and it is purely how the previous owner drove the truck.
Mine didn't look too bad at 100,000 miles when I changed mine.
