What did you do to your 2019 and up Ranger today?
I finished the differential install yesterday and got everything buttoned up underneath the truck. Next is getting the knuckles installed, weather permitting. I have and alignment kit on order that should be here Saturday. I just have to figure out what degrees equals out to in inch measurements.
The shocks also came in the day before. So, those can go on after I'm done monkeying with the front of the truck.
Well, the left side is back together. It was a bit of an adventure. In order for the knuckle to go back on, the wheel bearing MUST be removed from the knuckle. So I had to strip the whole thing down so I could get it bolted back on the truck. Reason being, there is not enough clearance between the end of the CV shaft the the lower control arm to allow the lower ball joint to be inserted into it's hole with the bearing in place. With the bearing out, it wasn't a problem.
Bare knuckle.
Splash shield and brake hold bolted back on.
Wheel bearing assembly, ABS sensor, and wire as well as the tie rod end reinstalled.
Knuckle restored
The rain is in the forecast all day tomorrow. So, it may be more trailer wheel painting. Plus, it's pay day. So, bills need paid.
Bare knuckle.
Knuckle restored
I’ve stopped paying my bills so I can buy more parts for the Ranger. It’s a disease at this point.
The right knuckle got installed last evening after work. The wheel bearing and brakes need to be installed yet. Being that it was getting dark and the socket on the torque wrench had slipped off and almost caused my finger tip to be split in two on the edge of the brake shield, I called it a night.
I need to pay bills and get some oil and a filter for the thing since it is due for it's Spring oil change. That, and I'm out of shop towels. Since it is due now and it is on jack stands, this is the perfect time to get it done. I also need to assess the miles accumulated since my daily work commute is about 68 miles a day, round trip. Oil change frequency may need to be adjusted as a result.
I just change mine every 5000 miles, which for me is about every three months. And add a bottle of Chevron Techron to the gas.
Lately I've been using Valvoline Restore & Protect 5w-30 with a Mobil 1 M1-209A filter (FL-400S equivalent).
Up until the new job, I've been at or less than 5,000 miles every six months but my daily commute has more than doubled (28 miles vs 78 miles round trip).
Chevron Techron has been done every oil change.
Valvoline Restore and Protect is something I've only started using. O'Reily's had a deal with that and a K&N filter. So I went with the HP-2009 (FL-400s equivalent). Advance and AutoZone only offered deals with their in house brand filters for some reason, with no option for a better filter, even with an up charge.
The front end is back together. I'll get the oil change and the shocks replaced tomorrow and take it on a test drive to see how I did on the alignment and if the rear shocks fixed the vibration issue.
The shocks got installed after I changed the oil and filter.
Unfortunately, the new steering rack has a different version of firmware. It's drive able, but I get an error message every time I start the truck. So, I'm going to have make an appointment with a dealership to get the installation finalized.
The alignment of the steering feels right, but the steering wheel is slightly cocked to the left. I got that adjusted. I just need to verify I didn't throw off the alignment in the process.
Lastly, the vibration did not go away with the new shocks. Since it was not there with the all terrain tires, and it was not a problem last year, I'm back to something being out of whack with the tires. I'm going to give the tire shop that @JohnnyO suggested a try.
I took my steering rack out for a test run. I have some friends that run Loosenutts Offroad that have never been to the Smokey Mountains. We had plans to so Hurricane Creek Friday. It was closed but we explored some gravel roads. Then set up camp at Max Patch Campground. Its a primitive, first come campground. Then I took them over to see Clingmans Dome (I'm sure I just butchered a Native American name) then checked anyway few more sites before working our way over to the Natahalla National Forest and found camp last night. The steering worked great weaving around the mountain switch backs. I'll drop the skids and make sure all the bolts are still torque to spec tomorrow. But seemed great. Was a nice easy ride to test it out. Let's say to reinsert confidence in the truck.
This is exactly my routine for Oil Change and Fuel Additive.
CMOS
Guys,
What kind of Amperage can the 7-pin Trailer connector drive?
Here's why
CMOS
Not enough to jump start a vehicle. Trickle charging would work. One of the terminals provides power for something like that.
Found the vibration problem. It is a bent rim. I guess since the offending tire was on the rear axle last year, we never felt it. As soon as it got moved to the front, the pro lem developed. The tire shop @JohnnyO recommended found it right away when they put it on the balancing machine.
So, until I get another rim, it will be the spare. At least it was a steel rim and not an aluminum one. Much cheaper to replace.
The specs say it's got a 30 Amp fuse so, yeah, not enough to jump, but could do a "charge".
CMOS
