2.3L ('83-'97) 2.3l
I cleaned and tested injectors. Put it back together and nothing. Had to be a fuel issue because I started it on break clean and it runs great. I guess I’m going to send it to the scrap yard I don’t know what else it could be!
I just reviewed the thread. I don't see wiring to from the injectors mentioned. Computer just grounds them. Do you have power to them with the key on? Note that even the 2.3 has 2 banks. So 2 injector power wires.
I will check that. I ordered a fuel pressure tester to make sure I got the right amount of fuel pressure. Maybe one of my new fuel pumps isn’t pumping good. I will make sure have power to injectors also. My next purchase was going to be a mood light to make sure they’re firing
lol yeah stupid swipe to text never writes the right stuff
It ran so good on the brake clean! I just want it to run!
I have power to both wires at the injectors. What’s my next thing to check?
I don't think I have read anything about checking the fuel pump relay. Swap it with one you know that works.
I have replaced it along with the connector.
My test light is only reading 9volts at the injector. It drops while I’m cranking it so I’m guessing they’re getting signal
  • 2.3l
https://a.co/d/05wBiMIU This is the one I bought. They’re all cleaned and tested. My noid light should be in today. I bought a fuel pressure tester and it didn’t have the adapter for my truck so I’m going to rent one from oreilleys or something.
So I put the noid light on it and it flashed for the first couple cranks then stopped.
If the pulse goes away it's either the computer or the TFI module or distributor that gives the rpm signal to the computer.
Well I guess I’m ordering an ecm. I’ve already replaced distributor and tfi
