2.3L ('83-'97) 91 ranger no spark
koke05
Forum Member
Federal Way
CT-USA
Vehicle
Drive
2.3L
accidentally posted to introduce yourself whoops don’t know if that matters but reposting just incase.
91 ranger was leaking oil out of every gasket on the engine (except the internals).
i had pulled the motor out to do a full service ( new crank, oil pump, camshaft gaskets , water pump, thermostat, intake and exhaust gaskets, new rear main seal, pilot bearing, clutch, flywheel, slave cylinder, starter, crank gear, cam gear, timing tensioner, ignition coil, motor mounts).
motors back in the truck but i was a doofus when installing the starter i had wired it wrong and had the ground on the starter and the ignition wire grounded to the truck 🤦‍♂️. got that sorted now the engine is turning but the ignition coils aren’t firing from either side. not sure if this has something to do with possibly frying the icm from my mistake but the connectors going into the coil pack does have 12v going into it with the key turned sooo??
don’t usually like asking for help but i’ve been stuck at this step and really want to get back out to riding my dirtbike but this is keeping me stalled. would appreciate any and all advice 😁😁😁
Guessing you've already checked every fuse (and fusible link) on the truck? Does the check engine light come on when you turn the key over to run but not start?
no check engine light and i’ve only checked the fuses inside of the bay which are all fine, along side with all the fusible links not being burnt or melted, i think it’s safe to assume they’re fine.
The check engine light should turn on when you key on, if it's not coming on the computer might not be turning on which would definitely cause your issue. Other than that I don't have any brilliant ideas yet... probably a missed ground somewhere, easy to do, or one of the plugs on the drivers fender going to the wrong spot or something dumb...
no check engine light so i’ll definitely take a look at the ecu later today. went through all the grounds and they’re all hooked up as well
update.
it was the icm
uh belts slipping off too lol i’m guessing my crank gear isn’t all the way in. ive been using a harmonic balancer installer to push it in more but now it won’t go in any further and i’m running out of muscles 😗
Upcoming TRS Events
