Help with stinger CAS & plug wires
devigiorno
NC, USA
Hey all, couldn't find much information on this.
I'm installing a CAS from stinger in my 2.3 Ranger (94) and now need to determine plug wire specifications. Does anyone know of an off-the-shelf kit for using AEM smart coils (IGN1A style)? I'll be using the stinger performance coil bracket.
If not, I can custom order cables from magnecor, but I'm also unsure of the correct length, boot styles, etc since the CAS/coils are not yet in hand.
Does anyone have experience with this that could help?
ok, I have to ask since I'm not up on some of the new acronyms, what's a CAS?
It is a cam angle sensor. It attaches to the distributor in place of the cap rotor etc. it sends a signal to the ECU in place of the crank position & Cam position sensors and allows you to run a coil near plug system.
Oh, a cam sensor, makes sense... I see it's aftermarket stuff, my whole setup is stock so I don't have any experience there...
I did do a quick google search and apparently that CAS should be an easy install from what the one facebook post showed... as for those coils probably have to get a set from what they came on and shorten them or lengthen them? Or maybe try HERE, it looks like page 30 has their ignition stuff on it, Pico is local to me sortof, you can deal with them or Summit carries their stuff too...
I appreciate it! Unfortunately I'm not sure that will work but I will look into it!
When I saw the what the IGN1A looked like I think almost anything would work, it looks like the end on a standard spark plug so you could go with some straight or 90's
