Cb radio
The more out in the open the better for tuning the antenna. That spot you showed in the photo would be fine though. As long as there's nothing within a foot or 2 of the antenna you should be good.
Okay
Generally speaking, as long as you aren't in an alley way or a driveway between two houses fairly close together, you should be fine. Radio waves bouncing off of buildings that are close together can throw readings off.
But you can get a good SWR and tune the antenna just fine while parked on the street in front of your house.
Radio traffic shouldn't make a difference since you are measuring reflectivity while you are transmitting. You won't be receiving any signal while your microphone is keyed. So, as long as you are set to read SWR, you should be good.
Ok thank you
Mounted on my toolbox
Kindof hard to see much in that pic...
I would agree that spot can work, but the toolbox itself (and its lid if that's what it's mounted to) do need to be grounded well to the truck bed.
I think having it mounted to the back-center of the box (or on top of the box) would be a better spot for it though.
Why would they need to be grounded? Lightening?
You need a good ground for the output transistors in the radio to be safe and for the antenna to work at all, and in a perfect world, you need a big "ground plane" under the antenna for it to work well. The ground plane shapes the radiation pattern from the antenna, without getting into the weeds.
Adding to what pentode said, it's so your antenna will have a good match (good SWR).
Wherever you mount your antenna, it has to have a solid continuous "plane" of metal under it for your radio signal to travel correctly. Obviously the best plane will be the expanse of sheetmetal that is the center of your roof. But when the antenna is mounted onto some other separate piece of metal that is smaller than the car roof or body (your toolbox) means that piece of metal (toolbox) will want to try to become it's own ground plane if it is not electrically bonded to the body of your truck.
The toolbox itself is much too small to function as an effective ground plane at 27MHz, so is why it needs to be grounded to your (larger) truck body so that it can become part of the bigger ground plane that is your truck.
Here's some further reading on this just so you're not having to take my word for it:
Thank you
I agree with everything here
On grounding to your truck bed, you don’t need to run a separate wire, you just need to make sure that the toolbox is grounded to the truck bed, that there is good continuity if you use a meter and touch the toolbox and then touch the truck bed
