Light Weight Construction Tires
Featured Build Threads
Jay11
5+ Year Member
Texas
'99 4.0+'98 2.5
Just learned that there are light weight construction tires, specifically a C class rating. I am in tall weeds with this. Much as I like all terrain tire look, I like efficient gas mileage better and need to make a confirmation before pulling the trigger. My 3 consideration factors are...I would like to stick with an AT tire, light weight construction class and priced up to $130 each, definitely below $140. Are the tires in the links below rated in the light weights category since they have SL Standard Load rating and weigh 37.7 & 37.9lb respectively? If not, does anyone have a favorite tire link that closely falls in the light weight class?
Michelin LTX Trail All Terrain 265/70R18 116T Light Truck Tire
Falken Wildpeak AT3WA All Terrain 265/70R18 116T Light Truck Tire
EDIT:
I don't haul loads. Truck is 99% a DD. Might move washer, dryer, fridge ....occasionally.
if you're looking for overall weight reduction check out the weight of 18" wheels vs smaller sizes.
a reduction in sidewall height doesn't always cancel out the increased wheel diameter.
if you're going for looks, do it.
Hard to go wrong with Falkens, I know a lot of people who run those and are very happy with them.
I think you'd be fine with the SL rated tires unless you're hauling a lot of weight often. That said I almost always go with C load rating on little trucks and E or better on full size trucks. Just personal preference but I think higher load rated tires wear substantially better. They are heavier and you may not like the stiff ride you get out of running higher air pressure in them. But I did go from P rated tires and normal shocks on my old Chevy service truck to E rated tires and coilover rear shocks... HUGE improvement! Steering, ride quality, tire life - all way better. If you're just using it as a commuter vehicle then it's a moot point.
Curious how much a light weight tire actually matters on a truck though in terms of actual real world fuel mileage.
Are SL tires the same as C load rated tires?
I had the Falken AT3WA's on my F-150. Rode nice, were very quiet. Ok in snow/mud.
I replaced them with AT4's, they discontinued the AT3WA in my size (watch your date codes if you get them) and I wanted something more agressive in mud and snow.
I had AT3's on a different truck before and the AT3WA is more of a highway tire but nudged a bit towards more goodness than an all season.
FWIW I ran Load Range C/6plys on my F-150.
AT4 is heavier than the AT3, a little louder than the AT3WA/
I don't think so. C is usually a light truck (LT) rated tire, 6 ply. SL and P are the same thing in my mind...4 ply. Maybe there is some cross over between sizes and brands but that's my understanding anyway.
Agreed, there is SL and XL and then the letter load ranges.
There is a newer "Load Index Rating" that is a series of seemingly random numbers to rate tires without the confusing letters (or worse ply rating)
the michelin defenders are great tires and light weight. i have them on my 04 3.0 powered ranger and they have given the best gas mileage of any that i have tried. probably similar to the ltx you have listed
I was convinced, both being equal on the Michelins, primarily based on my humble knowledge, due to tread depth 10/32 vs 9/32 until I saw the price is up today like an erratic stock, urgh! My shallow thinking has a layer in my mind convinced that the same adds a few more lifetime miles over the Falkens.
Then Wally displayed MRF Wanderer A/T 255/65R18 111T AT here, that have good ratings. I like that they weight 34 lbs vs 37 vs Michelin/Falkens but tread wear rating is 360 vs 500+ for the other two. Any thoughts on tread wear rating and the 34 lbs potentially translating to best MPG of all 3 tires?
not from me. i have no idea which if the rating effects mileage that much
Mileage ratings are in their lab under super ideal conditions and are more or less make believe.
A tire's Rolling Resistance is going to have much more effect on your MPG than the tire's weight will (especially on highways).
Rolling resistance (friction of it rolling along the pavement) is a continual thing your engine has to overcome as you're driving (much like wind resistance, though to a lesser degree), whereas once weight is moving (spinning), it takes very little energy to keep it moving (spinning).
The correlation between RR and a tire's Load Rating is much stronger in my experience ("E" being worst, "C" somewhere in the middle, "SL" being better, and "P" being the best). The inverse would be true for durability offroad, but it sounds like that wouldn't be as high concern for you.
I definitely would suggest the Michelin in a "SL or "P" rating if your priority is MPG. Only thing is Michelins typically don't have as much of that "macho offroady" look to them like BFG and Falken do. Function over form.
A road tire is going to have less rolling resistance than an AT tire will. Falkens tend to run heavy because of how they are made. They are a good tire, but if you are looking at gas mileage being the primary thing, you might want to look at an all terrain highway tire than a regular all terrain geared towards off road.
Rollong resistance will effect gas mileage as will a heavier tire becasuse it takes .ore power to push a heavier rolling resistant tire down the road and a heavier tire takes more power to get spinning up to speed than a lighter one. All terrain off road tires and mud tires tend to be heavier and have more rolling resistance compared to a road tire.
So, if you have no need to do more than gravel and fire roads, then you'll want a road tire or an all terrain highway tire. They won't generally look as aggressive, but if you are after fuel economy, that is the direction you'll be wanting to go.
Not saying weight doesn't affect MPG at all... But next to rolling resistance, it's rather insignificant (if any effect from it can be seen, it would be much more likely in stop & go driving than on an open highway).
You are correct. Stop and go driving is where tire weight is going to have more effect than if one is driving at a constant speed.
Upcoming TRS Events
Featured Ranger Based Vehicle
