Re-tap vs. clean threads
Clean out the threads or retap?
  • Clean the threads
    Votes: 1 7.7%
  • Re-tap the threads
    Votes: 3 23.1%
  • Neither
    Votes: 0 0.0%
  • Different situations require different methods
    Votes: 7 53.8%
  • I just like Rangers.
    Votes: 3 23.1%
  • Total voters
    13
Li'l Work Truck
Did you turn it off and back on again?
Pendleton
SC - USA
Vehicle
Drive
235/70 R15
Complacemcy is the key by which tyrrany opens many doors.
My MINI required that I retap the threads when installing motor mounts. I thought it was a bit nuts, until I saw what came out of it (hardened loctite). That got me thinking about the Ranger and possibe rust issues/buildup on threads. So, if there's an option, what do you prefer? To be specific, this is for  any bolt hole, not just the motor mounts.
depends on the situation, if its a normal bolt hole that all it does is hold the fender on, thread chaser all the way but like the above, if it holds an important part on the car then re tap
Tap holes and wire wheel bolts unless it is a rescue mission or something weird, then they get a die.
Re-tap, BUT….
Obviously, you’ve got to be extremely careful not to cross thread the hole. A lot of internal threads that are messed up, that’s easy to do.
And whenever I do that, if it’s a critical thing, I put in blue or red Loctite. I only use red Loctite if it’s a spot where I can get heat on it if I have to pull it down the road.
If it’s not that critical, I usually put E 6000/GOOP on the bolt before I screw it in. It stops the bolt from vibrating loose or out, but it breaks free very easily if you have to unscrew the bolt.
My two cents
Ditto, I agree, and I do the same thing, but one little thought for the less experienced.
Obviously, if you have to run a tap down the hole because the threads are damaged, you are going to be removing some of the metal, you’re just straightening up the channels.
Same thing on the bolt, if it’s really bad, you’re going to be taking away the high part of the threads. That can leave you with a gap when it’s all put together, a weaker situation.
Hence, if I re-tap the hole, I’m more likely to put in a bolt with rounded threads than taking them clean with a die, to preserve the metal, and that assumes it will screw in with minimal force. Depending on how bad it is, I just use new bolts.
There are rethreading die and taps. They have a different profile that reshapes the metal rather than cut it. That said I don't have any and use my regular old taps and die. IMO all they're going to do is remove dirt and rust, not new metal because it's the same as was used when new. Thread locker is good. There is a fairly new type that is orange and marketed as strong as red but doesn't need heat to remove.
You can use a threading tap to chase threads but just be aware it may remove metal and make the fastener fit looser than it did.
Thread chaser tool may be best if you have damaged threads...tap may be best if you are simply cleaning junk out of them. Just back off if it doesn't go in fairly easily or you're getting metal chips.
i only mess with the threads if there was something wrong removing the bolts, like galling or some type of metal transfer happened. i also only clean the threads and hole if there was some type of locker used on it already, i am going to use a locker, or the threads intercept a water or oil jacket and there is going to be fluid leak issue.
Different situations, different tools. That said there can be some overlap in which tool is used for which job.
You can use a tap as a thread chaser, but be aware that it's much more aggressive. Where a thread chaser might push a deformed thread back into place, the tap is going to cut it. Depending on the tolerances designed into the threaded connection it could also destroy the threads and make the too loose as mentioned above.
It should be noted that you can use a starting tap to clean threads in a blind hole, but you're going to bottom out before you hit all of them. A bottoming tap will go all the way down to the bottom. For both be careful with starting it to avoid cross threading or breaking the tap.
On the 5.0 I’m preparing, i ran a tap into every threaded hole i had access to. No regrets. On bolts, if it’s critical or high stress, use brand new.
In good mechanical training, you’re taught to never (well, almost) re-use a threaded fastener. You don’t know what it has experienced. Brand new is the only way to be sure it’s right.
For us DIYers and home mechanics, that get expensive. So, use common sense and do the best you can.
On threaded holes, if they are heavily worn, cross-threaded or otherwise damaged, thread chasers and taps are useless. They don’t add damaged metal back where it’s needed. They can only remove damaged stuff. Missing material in a cross-threaded, stripped or heavily worn hole means weakness. Then other repairs, such as threaded inserts are needed.
Like others have said, it depends on the situation. If the threads are so clogged with thread locker, you may have to run a tap through the hole in order to clean it out. It is better to use a thread chaser if you can. A thread chaser cleans out the exisiting threads with littl to no additional metal removed. A tap is designed to cut threads, so removing material is pretty much unavoidable. For areas that require a critical torque, I would avoid taping. For something, like welded on nuts to hold afender in place, dealer's choice.
I need to get a set of thread chasers.
It really depends on the situation. I’ve run taps in to clean out threads and I’ve even done the sloppy thread chaser and cut notches into bolt threads. Grease, anti-seize, or loctite as required. I also keep a stock of a lot of the U-nuts that are used and replace those as needed.
