- Mar 10, 2026
- Kansas City
- State - Country
- MO - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 235/75/15
New to the forum, I’ve got a new to me 1998 4wd ranger with the 4.0. It is not a California car as per the vin. I was told that it had been partially decatted and it’s been running poor. Intermittent loss of power at low speed, but usually fixed by a heavy stomp on the throttle. Running pig rich, lots of white smoke/vapor on startup. Obd eleven shows p1131 and p1151 codes indicating a lean condition and the engine running in closed loop only. I checked for vacuum leaks with copious amounts of brakkleen and nothing. That being said, I did a data log for short term fuel trim vs rpm and the graph showed that it runs much better when on throttle (around 4%) vs at idle (north of 30% yikes!) This was why I originally thought vacuum leak or bad o2 sensors, but the o2 sensors read in spec so I figured the car was really sensitive to cats. And the guy I bought it from said it was partially decatted so I hopped on rockauto and saw that there’s 4 cats on these cars. Looked underneath, saw just two, inline with the muffler and I ordered one of the two options for the catted y pipe that rockauto offers. Well it didn’t fit. Not even close. Talked to rockauto and apparently both available y pipes they sell are for cali cars only. So I’m stuck with that, if anyone wants to buy it, hit me up. But this brings me to my question. Did the rest of the rangers that had to meet only fed epa regs come with a catted y pipe or just the two cats further down the line. I really appreciate any help, and yes, I searched the forum first.
