SOOOooo... ALL aftermarket RADIATORS are the auto-trans version, zero M/T specific models?
Featured Build Threads
fixizin
FoMoCo is forcing me to buy a 'yota
⭐Supporting Member
Fort Lauderdale
FL - USA
Other
FLEX-fuel, baby!
Drive
0" bone stock
P235/75R15
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
My 27-year-old rad has developed a crack in the plastic portion, passenger side... (possibly related to my leak-fix???... https://www.therangerstation.com/fo...ver-coolant-leak-o.214554/page-4#post-2111182)
Anyway, in the short-term, gonna try to patch it with the 'High Heat' version of JB Weld, but I also know it's time for a new "heat-exchanger", but looking at the usual sources, it seems all anyone makes any more is the version with the ATF-cooler built-in... yes/no? If yes, does it fit without major surgery, and do I just cap-off the ATF ports?
Thanks in advance!
That's probably all you'll be able to find. The primary difference between auto and manual is the trans cooler loop in one of the tanks. Easier and cheaper for the aftermarket to stock and provide one radiator to fit both applications.
Yes, the auto radiator should bolt right in. You don't even need to cap off the ATF ports, there is nothing in them and it's an isolated passage through the tank.
Biggest recommendation is to verify that the replacement they are trying to sell you either matches the existing core thickness or is thicker. I have seen where aftermarket has tried to replace a dual-core radiator with a single-core. Especially down her in the south, you don't want to be reducing the cooling capacity of the radiator. If your truck has a single core radiator now, I'd possibly even check to see if there is a dual-core version available.
I only plug them to keep debris from filling the cooler, holding moisture and rotting it out.
I live in a very dirty environment though, your mileage may vary.
I'd probably cap them too. I think the ones I've bought came with caps. Just saying that it isn't necessary to have them capped to use the radiator.
I put an automatic transmission radiator in my manual transmission Bronco II because it was twice as thick as the manual transmission one. I needed the thinner fan shroud and an auto transmission lower rad hose because in my situation the lower hose port was a different angle. Cap the ports for the auto transmission cooler and run it.
SHeeeet... I don't want to have to replace MULTIPLE related components. AFAICT I've got a single-core rad (HOW to verify?), and it's always kept up, even when 4-wheeling in the scorching deserts around Vegas and Phoenix, w/ AC on MAX blast, and during the daily grind here in S. Florida, i.e. NO REASON to "upgrade"... bone-stock for me! ;)
PS: do I have to remove the tricky fan-clutch and fan for the rad-swap, or just the shroud?
Actually my latest move was to go to an electric fan, lol. The original move for me to the thicker rad was when I still had the 2.9 so I was desperate to try and keep it cool after having overheated and blew engines (yes, plural).
Finned part (core) of the radiator is twice as thick on a dual core as on a single core. Dual core will be almost as thick as the tanks, single core is pretty thin compared. If you aren't familiar enough to tell from looking, measure the core thickness and compare to listing measurements. Might not be exact same, but should be pretty close.
Separate the shroud from the radiator, and push back towards the engine and let it sit there. Once unbolted from the core support and the hoses disconnected, it should lift straight out. Especially on a manual trans with a single core radiator.
dual core probably has the metal tubes in 2 rows, one behind the other, with the fins in there. single core probably has one row of tubes going vertical with fins around it
I have a 5spd with the auto radiator. You don't have to cap anything, it's just an aluminum reservoir that is sealed with pipe thread and an O-ring on the face. Mine was leaking so I had to put in a new O-ring and some pipe dope on the threads.
  • SOOOooo... ALL aftermarket RADIATORS are the auto-trans version, zero M/T specific models?
IF I'm following you, this extra "reservoir" (which should just be filled w/ dead-air on a 5-spd) suffered a cross-over LEAK from the main coolant-filled part of the radiator, and if your truck had been equipped with auto trans, said trans would now be contaminated with anti-freeze and water, "milkshaked" in with the ATFluid??? 🤯
No, it was leaking from the O-ring which seals the coolant inside the plastic tank. The pipe thread was still tight and would have kept coolant out of the transmission fluid.
Upcoming TRS Events
Featured Ranger Based Vehicle
