- Mar 21, 2026
- Portland
- State - Country
- OR - USA
- Other
- Tacoma
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Manual
- Total Lift
- none
- Total Drop
- none
- Tire Size
- stock
I recently did some work to my '93 xlt ranger. Replaced a dead starter, and damaged ignition lock cylinder.
When I turn the headlights on the chime goes off. Either hi/low beam doesn't matter.
The turn signal is also acting up. When i turn it on it just stays on and doesn't blink unless I manually move the switch.
I'm thinking I must have pulled something apart in the steering column when took the cowling off. It was a chore and a half.
The relays and fuses seem to be fine... What am I missing here.
Probably not related, but the dome light is always on. I just took the bulb out. Probably should be fixed while I'm at it. Didn't test since the new cylinder install...
