What should my procedure be for timing? I’ve got good spark50/50 test. If it wont start or try with ether or gas, then it's electrical. Check your spark. Check your timing.
To be honest I haven’t made it that far on my journey yet. I can read my chilton though. Thank youHonestly i don't think its timing, but iirc, pull the spout and put a timing light on it. Should be 10 degrees btdc.
With all the work you've done, maybe a connector didn't seat properly. I had that happen to me. Took 2 months off and on before i figured it out,
Any idea what the connector could be? Or just meaning in general? ThxHonestly i don't think its timing, but iirc, pull the spout and put a timing light on it. Should be 10 degrees btdc.
First connection id check is the TFI plug and harness....since that kinda dangles around the bellhousing area a bit.Any idea what the connector could be? Or just meaning in general? Thx
I suspect some of the wiring to the fuel pumps or the fuel pumps themselves have been damaged from the exhaust work. It should always prime when first turning the key. And giving it a shot in the intake proves it's not getting enough fuel.
I see you have a 88 so you might have only one pump in the tank. Some of the models had two pumps, one in the tank and one on the frame.
Good Evening y’all. I got her running!50/50 test. If it wont start or try with ether or gas, then it's electrical. Check your spark. Check your timing.
