2.9L Crank But No Start After Starter Replacement
Honestly i don't think its timing, but iirc, pull the spout and put a timing light on it. Should be 10 degrees btdc.
With all the work you've done, maybe a connector didn't seat properly. I had that happen to me. Took 2 months off and on before i figured it out,
To be honest I haven’t made it that far on my journey yet. I can read my chilton though. Thank you
Any idea what the connector could be? Or just meaning in general? Thx
In general, but would most likely be one that had something to do with ignition.
First connection id check is the TFI plug and harness....since that kinda dangles around the bellhousing area a bit.
I suspect some of the wiring to the fuel pumps or the fuel pumps themselves have been damaged from the exhaust work. It should always prime when first turning the key. And giving it a shot in the intake proves it's not getting enough fuel.
I see you have a 88 so you might have only one pump in the tank. Some of the models had two pumps, one in the tank and one on the frame.
50/50 test. If it wont start or try with ether or gas, then it's electrical. Check your spark. Check your timing.
Good Evening y’all. I got her running!
It was the EEC relay… not the FPR this time lol. I experimented jumping the different wires with a paper clip. The solid red and red with green stripe got her going. It ticked pretty loud for 3-4 mins but eventually came down. Probably just the lifters after cranking with no oil pressure. It still seems to be a bit more than I’m used to, even after idling for 20+ mins and a little drive. I may just be skeptical as it’s been a few weeks, it always had a faint tick. I am really wishing I pulled all the relays off my doner truck while I had it 😣. I can’t find the right one online anywhere. When my FP relay went out I got lucky enough to get it at the junk yard. I doubt the truck still has any but I’m going to check tomorrow. I was able to find one on eBay for $25 so I’m pretty stoked.
Thanks again everyone for your help.
Well the relay worked for a few miles and stalled out lol. Investigated what was going on and could only assume it wasn’t grounding. Sure enough, relay didn’t have a good ground to the terminal. Put a new wire and needed a terminal anyway, she’s been great for 100 miles so far. Glad it was simple 😂
@ty.forestcom
If you desire to rid that ticking you should consider adjusting the preload on the lifters. It takes a little time and patients but can result in s a super smooth, quiet engine with no tick...unless your pushrods and rockers are beyond serviceable 👀
Good luck ..)
@ty.forestcom
Good luck ..)
Hmm, thank you. I am preparing to take a cross country road trip this summer and will probably end up doing that when I’ve got other things apart already. The truck has 40k original miles and is in impressive condition inside and out. I’d assume the rods and rockers aren’t too bad. Thanks again, is there any threads or information online to follow?
@ty.forestcom
At 40k, your rockers and push rods should still be serviceable but they do rate an thouroughfare inspection. If they are out of speech and you experience difficulty procuring replacements, phone Delta Camshaft of Tacoma Washington.
If you are unfamiliar with the proper procedure to properly adjusted the hydraulic lifter preload, just ask. I have never been able to get "no noise" following the manual and had to adapt my accidentally learned additional procedures.
@ty.forestcom
I am unfamiliar, can you pm me on here or that’s not possible? I’d appreciate any advice you have. Thank you very much
