Distributor option
Both seem similar. And they both work with a magnet.
That particular pertronix does not fit either distributor that i have. The power spark distributor looks to be a copy of the bosh that I have.
Just waiting for mon morning to call pertronix to see what will work.
In the meantime I put it back together and doing some testing realized the parts store gave me a unregulated coil.the ignition requires 3ohms of resistance.
Now waiting for new coil in hopes that was the issue to begin with.
The coil and the resistance that you require depends on what ignition system you finally end up with.
The original duraspark II distributor with a original duraspark II module requires a approximately 1.05 to 1.15 ohm resistance in the coil circuit with a original DSII type coil.
I used a original DSII distributor, but used a GM HEI module instead of the DSII module. I also used the original TFI coil. This system requires no resistor, just like the Ford TFI does not require a resistor.
When you call pertronix, see what they say about the resistor. I think some of their modules need the resistor, some don't. If you have the instructions for your unit, see if it talks about having or not requiring a resistor.
I am not sure about the other distributors and their modules and whether they need a resistor on not. It all depends on the design of the module. Some have current limiting built into the module, some don't and require a external resistor.
Pertronix instructions show coil resistance should be around 3ohms.
Powerspark instructions say more resistant than 1.5 typically around 3ohms.
So I ordered a coil with internal resistor claiming 3-3.3 ohms of resistance.
Update.
New 3.3 ohm coil had no change.
BUT, a buddy mentioned.spark plugs,so know #1 was fairly new I started with 2 and 3.
And find this,
Electrodes burned off and guessing it got hot enough to break the porcelain.
That got me looking at the wires I bought and they turned out to be solid core wires.
The system requires suppressor core wires.
So new plugs and proper wires and seems to be good.
Last test a run down I10.
So, this is a Powerspark distributor and not a points distributor with the Powerspark points conversion kit right? And you destroyed the plugs from using solid core spark plug wires?
That is interesting, Petronix wants solid wires.
Yes .this is still the powerspark complete distributor from UK.
I am ASSuming between 1.5ohm coil and solid core wires i had a meltdown of 2 plugs.
I installed the 3.3ohm coil and accel suppressed wire set, and it seems to be running much better.
That's not what their website states.
It looks like the newer ones want resister wires lol.
Its been a few years since I have dealt with them, I was never impressed enough with them to convert my tractors from points.
I have never used one,a friend of mine said he has had his about 10yrs with no issues.
I get to call them and cancel the one I ordered last week. Their timeline was around 3rd week of February before it would be ready.
