this small thing is leaking coolant, it’s on the back left side of the engine, I have a 4.L engine although a similar thing exists on my 3.L please let me know if you have any clue on what it is or what it does. Thank yall
I know it because I’ve been considering adding that to my older trucks although I’d have to rig up a vacuum connection and control, but it would help the ACI am glad yall knew that. If it leaked on my truck i would have had to take a pic and ask, too
You could always get an electric one, same wire that activates A/C clutch can activate the valve.I know it because I’ve been considering adding that to my older trucks although I’d have to rig up a vacuum connection and control, but it would help the AC
I didn’t know an electric one was an option…. Hmm…You could always get an electric one, same wire that activates A/C clutch can activate the valve.
25-1555M - Electronic Bypass Heater Valve
Old Air Products manufactures Electronic Bypass Heater Valveswww.oldairproducts.com
The only time there will be any vacuum to that valve is when you have the A/C set to MAX to shut the hot water off to the heater core.I have one that doesn't seem to be getting vacuum. Any clue what could cause that? Heat dial is all the way and the selector set to floor dash. (not AC side) 2000 2.5l
There were two different valves used over the years, the one went on only one hose to shut off flow, the other went on both hoses and when it shut off to the heater core it would circulate back. If it’s on both hoses, both hoses should get warm.Thanks, that's good to know. Not getting much heat out of it. One hose is hot the other not. Maybe it's stuck in the closed position? Plugged up?
