spark plug wire set
mikkelstuff
5+ Year Member
Brighton, CO
Friend of Bill W.
Any recommendations for a made to fit spark plug wire set for my 2002 Ranger 3L engine?
I tried the Taylor made 8.2mm set and sent it back to Amazon. There was simply no way even with lots of silicon grease to install the coil pack ends on the wires.
I want a set already fabricated from spark plug to coil pack. The only decent looking set I've found is from JBA performance on Summit Racing.
Without a doubt NTK. NTK makes very high quality wires, they aren’t expensive right now but they aren’t the cheapest either. I use them on my truck and I really can’t say if they work great or not because they are spark plug wires. My engine is runnin’ so… . But u can speak for the quality of the packaging and instructions. I had no need for installation instructions, but it was idiot proof each wire is labeled too.
Anyway the ones I’ve linked are custom made to fit the 3.0l. You’ll have long ones and short ones and medium length ones too.
Do your reading I think you’ll find that NTK makes higher quality than most brands.
You must mean NGK...
