4.0L OHV Soul crushed and seeking advice on starting problems
Why do you say that? I am researching one of these as well, and kind of was partial to the ones w/o the pump as reading online that's the usual fail point (the built in pump).
The ones with the built-in pump, you don’t need anything special, just fill it with smoke fluid and connect it to the battery.
The ones without the pump require you to use an air compressor and a special regulator. Wouldn’t be a big deal if I had a garage to work on stuff in and shop air, but a hassle for working outside with little consistency as to where. My air tools have been collecting dust for years because of that, I’ve gone to being more mobile in my tooling ever since Milwaukee came out with the 1/2” high-torque M18 impact.
Alright…
Little slow with my response because I’m working on cooking dinner…
Starter and bolts look better than I expected from that first pic. Unless the bolts are working loose it seems odd that it’s eating flywheels. Does it sound like it engages/disengages cleanly with no grinding?
Grounds can cause all sorts of issues even with cranking speed being ok. The normal place for the block ground is on the side of the block above the motor mount on these. Newer trucks take the block ground to the starter but anywhere block/starter/heads works. Normal configuration was a wire that went from the negative terminal to the frame and then over to the block. I usually run separate 4 gauge wires. That one you have on there all taped up concerns me about how well it’s doing its job.
The “dinky” ground wire is by the battery, just a short bit of 10 or 8 gauge running from the negative terminal over to the core support.
That is a super crusty pump! Yikes!
Wonder if the TPS (throttle position sensor) is acting up. More a curiosity thing.
Unplugging the IAC and it idles right tells me there’s a vacuum leak most likely.
That delayed spark sounds fishy…
@holyford86 , you have any suggestions?
I've seen missing engine to teansmission dowel pins or loose bolts cause issues like you've been having chew up ring gears.
Check your cranking voltage at the pcm and edis module to see if it's dropping very low during cranking.
Vacuum leaks shouldn't cause an issue during cranking unless they're giant leaks, which should be obvious.
As previously mentioned, it wouldn't be a bad idea to give the inside of the pcm a good look over for leaking capacitors or other corrosion damage. I had a couple failed or failing capacitors inside mine, it didn't cause anything super noticeable as far as driveability but the electrolyte is conductive and corrosive, which will short things out and cause issues or turn your pcm into a brick. It's best to catch them first. If you're reasonably good with soldering, a cheap soldering iron, a desoldering braid and vacuum kit, and some lead bearing electronics solder will suffice, and you can get it all at harbor freight. Digikey or similar has all the components you need from high quality manufacturers for reasonable prices as well.
On the wiring, I was specifically thinking of the twisted pair shielded wire running between the EDIS and the crankshaft position sensor. Probably unrelated but is that sensor and harmonic balancer in good shape and clean? That could cause all kinds of issues. Especially if it causes the ignition to fire at the wrong time. I've even heard it suggested that hard start due to timing could cause flywheel/starter damage. I could believe it if the engine suddenly fired and started running hard enough.
I say all of that because a 91 has no signal to the tach without the EDIS module. And it pulls from the crank position sensor. If either has a problem it could cause the tach to jump like that. I wonder if a bad ground could have starting current leaking into the crank signal wiring?
Lots to reply to. I really appreciate all the insight you guys are giving me. Happy to have joined this forum and community!
I did all the work back in June but I don't remember missing any hardware between the transmission and engine. I can recheck later this week and see of things are still tight. I know I used thread locker on the flywheel / clutch assembly. Think I did the same on the transmission bolts too but I'm less certain on that.
I would also confirm that the starter has the right gear on it. The engagement is way less than it should be on the ring gear, not like the starter shifted a little, more like the starter gear has too few teeth.
Long shot, but also try to confirm that you got a manual starter when you replaced it. 4.0 starter's have slightly different "nose" lengths for manual and auto trans.
Okay. I just pulled the starter out of the truck the bottom bolt was very snug, the top one actually wasn't the tightest. Maybe 5 foot pounds on it? Oops. I do believe this is a manual starter based on the images I am seeing on RockAuto. Look right to you?
Having said that though - it does actually seem like the starter is making minimal contact with the ring gear when trying to turn the engine over. Attached is the current condition of the ring gear. In the position it is currently sitting, the flywheel isn't making contact with it and it is not turning over. The pics aren't the best, but you can see where only the tips of the ring gear are worn down. Other than that there's still a lot of each tooth there. Surely it can't be designed to only use that much of the tooth as a contact surface for cranking over? (P.S. See! I cleaned the plate before reassembly.. not the gunk inside the bell housing but I did clean the mounting surfaces lol)
The original sensor had a ton of oil caked onto it. New one is clean as is the balancer (probably flings any oil and crud off while running). It's actually one of the few clean spots on the engine. It had a huge PS fluid leak before I replaced the lines. Now I think it's got a bit of a rear main and the upper radiator hose has a leak.
Can I test that (without it cranking over correctly even)?
I have a pretty average multi-meter and a test light in terms of electrical tools which isn't that much.
Yeah I don't suspect a vacuum leak (or at least one to cause these problems for me), was just replying to someone else who mentioned it as I had commented on the idle sometimes being way too high.
I did already pull the PCM. No corrosion that I could see and all traces appeared to be intact. I replaced the capacitors anyways due to age and they did have a tiny bit of a bulge at the top.
And welcome to to TRS.
Thank you! I feel very welcome. Lots of people trying to be helpful and so far one has been nice. I'm really happy such a forum exists!
  • Soul crushed and seeking advice on starting problems
So I did check and I have 10 teeth on the starter. The flywheel I installed was this one from Orielly's. I don't know if that is at all useful info but I figured I may as well put it out there.
I can find a lot of people talking about similar problems and headaches but none seem to offer a real solution which is a bit disheartening.
I don't have a starter "nose" measurement, and I can't tell the difference manual versus auto starter by just looking at a starter. I'd need to see the two side-by-side to see the difference.
The only suggestion that I can think of, is see if there is a parts store nearby (maybe a "big box" chain store) that has both 4.0 starters in stock (manual AND auto), and see if they would let you come in and look at the two, comparing them to your starter.
That would also let you check where that thrust bearing, that stops the drive gear, is supposed to be (I'm not sure that it looks right). Replacement parts quality has gotten so bad, that you can't really rule out, that the new starter that you put on it, may have a wrong part put in it or be incorrectly assembled.
It's frustrating, I know, but don't give up. You'll get it squared away.
I can try checking around, but just comparing pictures all of the manual transmission starters for a 4.0 ranger on RockAuto have the same rectangular cutout that can be visible in my 2nd picture of the starter while none of the automatic ones have that.
On the chance that it is a starter problem, you think there's any hope that flywheel will be fine? It feel like the starter isn't making nearly as much contact as it should be with the ring gear. There's some spots that are shaved down a bit, but overall I did not see a single missing tooth or even one that's chipped in half. Just a tiny bit shorter.
Also, should the bolts be able to have any kind of wiggle room in the starter? The bottom hole is quite snug around both bolts, but the top one I am noticing has maybe 1-1.5mm of clearance and the bolt can wobble around.
Seems like that would potentially allow the starter to be poorly aligned, right? Because that plate between the engine and transmission is just for spacing from my understanding and doesn't actually align the starter does it?
It is frustrating and it's hard not to get discouraged. I literally did all this work with the truck on jack stands out in front of my apartment, risking a getting into trouble. I did it on my back mostly by myself with a bad shoulder so I am really not loving the idea of doing it all again.
I'm a little late to the party, but I did skim over most of the discussion.
Also, most of my knowledge comes from 2.9's, so...
Is the Escort bendix modification relative to the 4.0 as it is to the 2.9? I've had a couple of 2.9's do the very thing you describe. Between the separator plate getting a little sloppy and cheap aftermarket replacement parts having terrible tolerances it seems that most of them benefit from the mod.
NOTE: I see now that your starter is already a 10 tooth. Does anyone know of an 11 tooth bendix that might swap on?
@TacoBelleGirl , the aluminum plate does pretty much align the starter. How does the starter fit in there, with the bolts slightly loose can the starter wiggle around or is it pretty set? I’ve had where the plate is bent and the starter can wobble around. Looking at the pictures, it looks like it’s a little bent at the top and has been touching the flywheel in an inappropriate way. I’d maybe bend that back out slightly, could just stick a screwdriver in between. Might be letting the starter shift slightly on that bolt that isn’t holding it well.
Definitely a puzzler here, usually things are fairly obvious when the starter isn’t doing exactly what it should.
I don’t think I’d worry too much about that flywheel just yet. I had the bolts come loose in my F-150 like 7 years ago and it chewed up the flywheel pretty good. Worse than yours, but still no broken teeth. I snuggled the bolts back down when I found it (I assumed the starter was going out so I was roll-starting it for like a week and a half waiting to have money to buy a starter). Still working fine.
I hear you on frustrations, working in less than ideal conditions, and getting discouraged. It happens. Most of the vehicle work I do is outside on the ground. I did the whole working on stuff in an apartment parking lot when I was in college. I have a limestone driveway to work in now. Finally got smart enough to do what I should have done 15 years or more ago and built myself a tiny workshop this year. It’s still not done, I’m gonna be running around this week collecting up stuff for it. Hate to take time away from trying to fix my trucks, but I need the shop finished both to make things easier on me and for my sanity.
My green Ranger I started a build on about 6 years ago. Major work, doing a 5.0 AWD swap plus axles and lowering and frame repair and… yeah… I got it together after 3 years, promptly chased my tail with problems, had it working ok and about 9 months after getting it working ok I went looking for an exhaust leak and found a broken frame and the exhaust leak. It’s been on jackstands in the driveway since the summer. Between getting pulled in other directions, trying to keep my Choptop and F-150 on the road, money, and being a little discouraged like I’ll never get to enjoy the thing, it’s been rough. I’ll get it though, I’m too stubborn or stupid to really give up.
I’m going to agree that the starter isn’t sitting tight or shifting. Somewhat common problem on older rigs. Something to be mindful of.
Electrical issues are also common. I’ve been a victim of this and I do electrical work. Had the ground cable rot apart inside the insulation without visible signs of a problem. I was fighting no-start/hard start and a host of crazy electrical issues and just happened to get curious as to why the main ground off the battery sounded crunchy when flexed. Skinned some insulation and junk. Ever since then I don’t play, either whenever I have things torn apart anyway for something or I start having electrical issues, I make up new cables out of 4 gauge welding cable. Ground and hot to starter, ground to frame, and I replace the dinky ground to the core support with 4 gauge. Use No-Alox (hardware store electrical section) or dielectric grease on things.
For the no-start, I’d suspect a fueling problem. Check the vacuum line of the fuel pressure regulator for fuel, it shouldn’t have any. If it does, the regulator is bad for sure. Also if you can, check the fuel pressure at the rail. No hot start can often be low fuel pressure vaporizing fuel in the rail which causes no start. These older trucks you can cycle the key a couple times and push fresh fuel into the rail to try to eliminate that. If the pump is weak or the filter is plugged this won’t really help though.
Another huge problem with these older trucks is the capacitors in the computer pop and can cause all sorts of issues. It’s an easy thing to check, pull the battery cables and pull the computer (passenger side kick panel). Remove the cover on the computer and look. Blown capacitors sometimes are physically broken but will always stain the board under them. The corrosive juice in them can also burn out other components on the board.
This TRS site is Awesome & all you Folks here are wonderful!
Lookit at what I also found... https://www.therangerstation.com/te...nic-engine-control-troubleshooting/#gsc.tab=0
("TFI" problems sound familiar.. ?)
:cool:
What's the mod? Swapping the bendix from an escort starter motor? The 2.9 and 4.0s seem to have different starters, but it kinda looks like the 2.9s use the older style starter motors that people will upgrade to the newer style like found in the 4.0 so maybe they are compatible?
Feels like a pretty snug fit. Tiny bit of side to side play but I actually only feel it on the bottom bolt. I'll bend the plate back out before putting it all back together.
You can see exactly how snug it is in this video. Very little movement I think, especially considering I am just holding it into place and the bolts are only there for a general alignment.
Well that's a relief and indeed the answer I was hoping to hear. Thank you for easing my mind a bit!
Haha yeah if I had land I would have built some kind of garage or mini workshop ASAP, but land ownership isn't really within my reach at the moment. Good luck on the 5.0 ranger! I've got a 91 econoline with a 302 in it and it's a good engine. If it wasn't for a lack of garage space (and realistically that I should sell that van) I would be very tempted to swap the engine over to ranger. But honestly the 4.0 OHVs are pretty torquey and I feel like that they have more than enough power for such a small truck, especially when paired to a manual transmission.
Thanks for the link but this doesn't apply to the 4.0 rangers. They are all the EDIS system which comes after this one. And are generally considered to actually be quite reliable from my understanding.
I did just come across this link though which has some info to help narrow things down a bit..
Need the truck to crank over reliably first.
I agree that it looks like the starter gear isn't making good contact with the flywheel. Not sure how that 's possible though with out something being the wrong part or at least worn/broken. Hmm. I don't see any damage to the starter teeth. May just be the picture though
I see what you mean about the square inset area. Definitely looks like the manual starter. Both parts on RockAuto are listed as 10 tooth gear. It seems pretty unlikely they'd have 2 different 10t gears but possible I guess. If there were they probably wouldn't fit in the same place.
Pretty sure that's the same flywheel I'm using. As long as the right one was in the box. I can't imagine anything else being close enough to bolt up and match the clutch though.
As for the crank sensor, I've heard alignment of those is critical. Never had a problem with it myself. Can't really see how that would cause the tach to move either though. I could see an aftermarket sensor being sensitive enough to pickup on the magnetic field of the starter spinning. Weird and unlikely but possible I suppose. I doubt that would hurt anything as long as it stopped when the engine fired. Could cause the timing to be off when it first fired I guess.
Looking closely at the teeth I can see some wear, but very minor and none of them are broken.
The flywheel matched the old one I was replacing and didn't have any weird fitment issues so it is the right one as far as I can tell
I don't recall there being any adjustment available on this crank sensor and there seem to be no mention of it on charm.li, but I will double check when I get a chance.
Probably be a couple days due to work and other responsibilities but I will double check that and I think actually fit the starter back in again. I realized there's a small hole in it where I can use a screwdriver to push the bendix out which will let check how it's mating up to the flywheel - might be useful! Not sure if I'll be able to get a good picture of it but I'll try.
I am wondering if there's a small chance all the unhappy noises and cranking issues are just from that top bolt being a tad loose.. Seem possible at this point. I guess I'll know with it fitted back in and checking the clearance.
edit: I had accidentally hit the keyboard shortcut to post my reply before I was done
It's a good possibility. I've actually had the opposite experience with mine. Crawled under the truck to check something else and found the starter 1/2in away from seating and hadn't noticed anything... LOL
:cool:
We work hard to keep this a great site and resource. Despite what it says by my name (there was a big forum reset in 07), I’ve been here since about 02.
TFI was part of the older systems, the 91 4.0 doesn’t use it, but there is a module that may or may not be affecting things. I’m not exactly sure where it’s located on the Ranger, it’s been awhile since I’ve looked at it because it’s far more reliable than the old TFI. When I converted my Choptop to essentially a 91 4.0, I just found a handy spot on the core support and bolted it in. I suppose anything electronic could fail after over 30 years though…
