holyford86
Some guy with a problem
⭐Supporting Member
💻 TRS Socials
Boosted (Not Stock)
- Aug 6, 2007
- Age
- 39
- Plattsburgh
- State - Country
- NY - USA
- many
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- 7
- Tire Size
- 33x12.50R15
I know you're still working on the post (and issue) but the thing that told me to check the neutrals when you were describing the issues reminded me of the issues I had when I moved into my house.So, I completely agree with you guys on its a neutral problem most likely and somewhere between the power company and the breaker panel.
As to the panel/subpanel, there is a panel and subpanel next to it. I’m no novice electrician, I immediately started isolating things and trying to work through the problem because an issue with neutral was my first expectation. Of course when I couldn’t isolate a problem, I then started checking everything, had a text conversation with @holyford86 and a phone conversation with a local contractor that I’m good buddies with.
I did find a pair of circuits in the subpanel that were ohming across the hots, and they are both short basement runs.
And hang on while I finish this post
I would get horrible voltage sag when any load over a few amps was operating, to the point that my ups would trip when the fridge came on. It would dip below 90v from the outlet at times.
The power company is going around upgrading meters and replacing meter boxes as necessary, they did mine in May and all of the issues went away after that. The only things that worked perfectly the whole time was anything 240v.
The house is a manufactured home from the early 70s with copper wiring and seems to be fine from a wiring standpoint now that I've also had the federal pacific panel replaced as well.
