- Apr 13, 2009
- '06, '11
- 3.0 V6
I've never heard of double wall brake line. A double flare for sure is required. And that is what I thought he meant by " double wall "...
That's the thing, it appears I have different shoe types, but they are both primary shoes (less pad). That shoe on the right with the rivets, it's like they took the pad and slid it further down the steel part. Both shoes in that picture have the same length of pad, they are just in different spots on the metal. I'll try and take some better pictures!So... the two shoes you have pictured... it appears you have a secondary shoe (no rivets) and a primary shoe (riveted lining).
The shorter lining is the primary shoe and is put as the forward shoe on the backing plate. Longer lining goes on the rearward side.
FYI... Riveted shoes are typically the heavy duty variety. Rivers are stronger then bonding.
If ya can't get it together... pictures please. Those are really helpful.
I have a full set of riveted shoes on the truck right now, and a full set of non riveted I just bought to compare.Honestly... it looks like you had a secondary shoe in the primary position to me.
I learned something here. I thought brake line was single wall. At least it always looked that way after cutting and before flairing.
Yeah you're right, barely looks like it's coming through. Whoever did these brakes last time had them right behind the horse shoe clip. I'll correct that tomorrow and see if anything gives, thanks for taking a look. The other thing i thought to check was the self adjuster. That also came in the crate o parts along with the springs and shoes. I have the old one but that sucker is rusted open, I've had it soaking in penetrating oil. I'll hit it with the torch and see if I can't get it moving again.This picture clearly shows the secondary shoe held off the anchor pin.
Those riveted shoes look proper to me. Likely just a better quality set of shoes. I'd take the other set back.
The wavy washer on the park brake lever pin should go on before the pin goes through the shoe. Ensure the horse shoe clip is in the groove before squeezing it down. It just doesn't look correct to me as it is.
