- Apr 13, 2009
- '06, '11
- 3.0 V6
I've never heard of double wall brake line. A double flare for sure is required. And that is what I thought he meant by " double wall "...
That's the thing, it appears I have different shoe types, but they are both primary shoes (less pad). That shoe on the right with the rivets, it's like they took the pad and slid it further down the steel part. Both shoes in that picture have the same length of pad, they are just in different spots on the metal. I'll try and take some better pictures!So... the two shoes you have pictured... it appears you have a secondary shoe (no rivets) and a primary shoe (riveted lining).
The shorter lining is the primary shoe and is put as the forward shoe on the backing plate. Longer lining goes on the rearward side.
FYI... Riveted shoes are typically the heavy duty variety. Rivers are stronger then bonding.
If ya can't get it together... pictures please. Those are really helpful.
I have a full set of riveted shoes on the truck right now, and a full set of non riveted I just bought to compare.Honestly... it looks like you had a secondary shoe in the primary position to me.
I learned something here. I thought brake line was single wall. At least it always looked that way after cutting and before flairing.
