Where to run Power thru Firewall
Featured Build Threads
cmcolfax
Forum Member
EMT / Paramedic
Firefighter
Williamsburg
VA - USA
Other
2007 Volkawagen MK5 Rabbit 2.5
Vehicle
Drive
None yet ;-)
Facta Non Verba
Yes, I searched. šŸ¤·ā€ā™‚ļø
2011 SOHC 4.0 5-Speed SuperCab
For those of you who have added amps and / or subs to your truck, where did you pop the power cable thru the firewall?
There is the big cable bundle below the fuse and relay box on the driver side, but I can't see how I am getting thru that. Hell I can barely get my hand on it!
There has to be another spot!
I need to fit true 8ga, nothing bigger.
Look and see if there's any unused rubber grommets on the firewall. If so, punch a hole through the rubber and run you wire through.
Always fuse an added power wire at its source.
That's where I ran power in and accessory wires back out on my 06.
The big rubber harness grommet lower left side.
I go through that big rubber boot / grommet down above the pedals that the other wires go through. I use this Wire Insertion Tool to poke the hole through and then slide the wire through the opening in the tool.
If your truck has an automatic transmission, there should be a nice sized unused grommet where the clutch pedal rod would have penetrated. I jave also added wires through the existing wiring grommet on the passenger side below the heating duct. I have also ordered grommets online and drilled new holes behind the seats.
Always.
I'm mounting a 40amp fused distribution block to the inside of the fender next to the fuse and relay box.
I am picking up the power from one of the two studs that feed that box from the battery.
It will be all of 12" away. šŸ˜Ž
Manual. šŸ’Ŗ
I thought about crossing over to the passenger side in the engine compartment and coming thru the firewall over there but I didn't see any good options there either and since I'm coming off the feed to the fuse and relay box to my fuses distribution block then thru the firewall I was trying to keep the run reasonably short.
That's a pretty slick tool!
I think I have already "spent" $15 worth of frustration trying to find a place/way to get this power wire thru the firewall!
No issues getting thru that thick rubber grommet?
No issues with catching/nicking/cutting wires in the harness when you pushed it thru?
Always.
I always use a piece of fusible wire in situation like that. The light blue wire coming out of the underhood fuse block is fusible wire.
That tool is a life saver. I used to poke a hole with a screwdriver and try to force a wire through usually with it just bunching up inside somewhere. Now it's fast and painless.
I bought one.
O'Reilly's had it for $8.99
Gonna try to get the 8ga power cable run today if it doesn't rain.
I bought one.
Rainwater will lubricate the grommet and help the wire slide easier.
:yahoo::icon_rofl:
I usually just pick whatever looks like it will work for routing. I’m not afraid to drill a hole and add a grommet if I need it and I’ll waterproof anything I need with silicone, preferably marine grade. My green Ranger has 1/0 power and ground run into the cab. I went through sort of near the gas pedal because I was running it into my custom center console. If I think about it I’ll get a couple pics today.
In situations where it might not be a permanent thing (like I have a few wires coming out of the back of the cab but haven’t decided if I’m going to run any more wires through there or not yet, working towards a final wiring plan though), I put duct seal (electrical section, hardware store) to seal up the hole.
I used the grommet that the hood release cable runs through. I got both 4 gauge wires through with ease.
Event Coverage
Featured Ranger Based Vehicle
