- Aug 23, 2025
- Lubbock
- State - Country
- TX - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0L
I believe the 95 door panels have a more pronounced bump where it meets the dashboard. I looked into doing that as well bc the 95+ up dashboards seem to hold up better overall.
I believe you would want to swap out the door panels as well and I haven't looked into compatibility before. Luckily for you, you and pull the door panels off and see if it would be within the realm
I’m seeing that rangers started obd2 in 1996. Is that correct?I don't believe the ECU will work in your 94. 94 was ODB1 and 95+ is ODB2 among other things.
