- Feb 21, 2012
- Northern Idaho
- 4.0 V6
- Total Lift
- 8 inches
- Tire Size
- 37"
So on my last trip, 14 hours on the trail, last hour on our way back, it started running rough and would loose RPM and die. Shut it off and restart it, it fires right off. Runs rough and will back fire messing with the throttle. It tends not to do it a low idle. But 4-5 gear it falls on its face… I had extra sensors, maf, bap, o2 sensors. Nothing has helped. I thought it might be the pip sensor in the distributor. Bought a DUI one, set base timing to 10* no change. Changed fuel filter. Fuel pump is less than a year old. TPS is set to .996. Fuel pressure is 40 psi.
I’m kinda at a loss. PCM? Or fuel system? Does this pcm look? Im nervous about the spot.
