- Mar 31, 2020
- Vermont
- 4.0L
- Tire Size
- 16
So,
I am currently looking at purchasing a remanufactured transmission for my 2003 Ranger. The synchros are beginning to show crunchy signs of soon-to be "salutations" if you will.. Which has been going on for quite some time... After looking into options for replacing only the synchros, I decided it only makes sense to buy a new transmission all together.
I know that there is only so much I can do in order to optimize the towing capacity of such a small truck. (Notice, I said optimize, not increase.. As it's been discussed in previous forums that legally you cannot tow more than what is specified by the manufacturer.....)
But I started to think about options revolving around this transmission swap I am planning to do - regardless of my towing needs.. I know my current transmission is the M5OD. I am unsure what the Axle ratio is but... My truck is a 4x4, has 135,000 on the engine and the clutch was replaced in early 2020 at about 90,000k miles.
As most of us know, these Rangers have a significant reduction in towing capacity when they are a manual transmission... I have also read that the main reason for this reduction in towing capacity is simply because Ford wanted to reduce the number of claims being made from drivers who managed to burn out their clutch's too soon because of poor driving habits, while towing. So, does getting a "better" transmission really make a difference? Or would the standard M5OD simply do the trick...?
I am wondering if anyone here has had any luck with products or "modifications" that have helped optimize their towing capacity for the 4.0L v6 Manual Rangers ? Any and all recommendations or insights would be much appreciated.. So far, from looking into this online, I have noticed some people recommend the following...:
- Use a weight distributing hitch (but apparently they're not too many that will work for a small truck ?)
- Get a "high performance" clutch to extend its' life and reduce wear and tear (recommendations?)
- Adding a better transmission cooler?
- Add some heavy duty clutch bands?
- Swap out the rear drums for disk brakes (I've seen many guys do this, does it in any way affect my insurance?)
- Use a trailer that has integral brakes
Just looking for some help being pointed in the right direction.. Feel free to ask about any more information regarding the truck, and its' uses.
I am not trying to tow a giant RV by the way -- I just do a lot of home renovations and such and if i can safely transport a tools trailer or a dump trailer...
Thanks!
Thanks!
