Distributor option
If it's black/yellow (more black than yellow) then it went to the A/C compressor clutch.
Well i already have a single wire ran along my ac line that goes to the compressor, i thought thats what signals it to kick on and off. I traced the yellow and black wire and it looks like it runs to the passenger side solenoids/relays, not sure if it had something to do with the tfi or not
as for my ranger i mean everything on the carb worked afaik, idled and ran on its own just has a hesitation at WOT, rebuilt carb and replaced fuel filters and stuff and no difference. I figure it might be something with the timing advance failing possibly?
A hesitation at wot? Describe exactly the symptoms. Are you at a stop and then punch it to the floor? Traveling at 30mph and then punch it? Something else?
its a manual, driving or idle when you go WOT, it will cut out for a brief second then pick back up. if you slowly step on pedal its fine. I understand this could be a carb issue with the primary jets however upon inspection primaries and secondarys seems to function just fine, unless thats something you cant "diagnose" by eye. Either way im replacing the carb and whole ignition system so it doesnt really matter at this point.
im more concerned about fixing these damn oil leaks.
Sudden acceleration bog would most likely be the accelerator pump not adjusted properly or the (it may be leather) diaphragm worn or dried out.
Is your PCV system working? That would be the little silver elbow stuck in one of the valve covers. With the engine idling, you should be able to pull that out of the valve cover and put your thumb over it, and it will suck on your thumb if it's working. This pulls all the nasty stuff out of the engine and burns it. And since it also puts some suction on the interior of the engine block, it can aggravate engine leaks if it's not working.
Yup replaced PCV
I replaced the pump and diaphragm, cleaned out carb and still same thing. Alot of the vacuum lines for the tfi are broken so i figure its a spark issue and not a fuel issue
My understanding is that parts dry up after so many years, and then another company comes along and buys the moulds and the tools to produce parts after a period of parts drought. A case in point was a few years ago, a friend of mine was rebuilding his 1987 Camaro Iroc and needed a new radiator. Well, he couldn't source one (now he can if he wishes). I think he wound up using a radiator from a 1500.
I'm a little surprised that this kind of part has been a little slow on the uptake, but it's not exactly in high demand here in the US of A either.
Where did we end up on this? I keep trying to circle back to it because I want to add it to the Tech Library.
My understanding is that the Powerspark distributor works in the 2.8 and has a built-in ignition module. If true, then it would seem to me that you could replace the Duraspark conversion by using a Powerspark distributor, a coil, and a 2BBL carb. I've been waiting for someone to actually do this, share some photos, and confirm it.
@CaptLongshot @AzLizard @ISX_15
Seems to me that one simply needs to adapt for a Bosch set up then.
So a 2+ yr update.
About a month ago I started having issues like I was running out of fuel.
The truck would run around town but if I got on the freeway at 50+ the truck would start backfiring and loose speed.
Changed all filters.(i installed 2 inline filters) pluse the carb filter.
No change. Pulled top of carb off and made sure bowl and jets were clean. No change. It seems to get worse as the truck warmed up.
At this point I'm thinking the powerspark is failing.
Today I'm going to reinstall this distributor with the 3? Wire hookup to see if that is the issue.
Being the powerspark distributor is a bosh, I'm looking at maybe replacing it with a pertronix unit.
Update.
After rebuilding the carb and testing ingintion module. I believe it is failing.seems the UK units don't like the heat,and I live in the SW desert of Az.🤨
I need to contact pertronix to see if the 2 are compatible.
If any of you have looked into this,please share.
The pertronix I have messed with, are retro fits to a points distributor. They may tell you this, that you need a 2.8 points distributor to use their kit. If they do, I was thinking about this route before, and Cardone at the time (several years ago) did have some 2.8 points distributors in stock. I think I was looking up a very early pinto with a 2.8 and they had points distributors.
You can pick your favorite vendor and see if they can get a distributor for a early car with a 2.8 if you need to go that route.
I could be wrong,I'm thinking the powerspark distributor is supposed to be a copy of the bosh points distributor.
I do have one from a 2.8 mustang that I bought from a RS member if not.
The pertronix conversion kits I have done, they have a special cap that fits over the cam lobe on the shaft of the distributor. I never looked at it very close, I suppose it may have magnets or something in strategic places. Then the module mounted on the points plate once the points have been taken off. It picked up whatever was in that cap as it turned.
