- Nov 12, 2018
- Phoenix
- State - Country
- AZ - USA
- Other
- 18 Toyota Camry LE
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.8 V6
- Tire Size
- 245/60r14
Gotcha, what about the two vacuum lines that run to it? It runs to the passenger sideIs that a heater valve? I am not sure of the real name but i think it lets the hot water into the core?
Your pic, is of the air valve for the Thermactor system; that's the belt-driven pump that blows air into the cat converter.
ok thanks im sure theres threads on how to bypass it so im not even going to bother asking.Your pic, is of the air valve for the Thermactor system; that's the belt-driven pump that blows air into the cat converter.
The top valve is the thermactor divertor valve, it changes where thermactor air is sent- upstream to the back of the heads or downstream to the exhaust in front of the cat. The lower part is the bypass valve, it dumps the air under certain conditions. When the engine is cold and running rich thermactor air would likely cause backfire.Passenger side.
Is it ideal to bypass it or completely delete it? Do people just run a smaller belt afterwards or does there need to be a idler pulley in place?The top valve is the thermactor divertor valve, it changes where thermactor air is sent- upstream to the back of the heads or downstream to the exhaust in front of the cat. The lower part is the bypass valve, it dumps the air under certain conditions. When the engine is cold and running rich thermactor air would likely cause backfire.
Im sure all the buildup is YEARS of leaking oil, once its all clean i can pin point it. I just hope its nothing on the front assembly. I dont mind replacing rear main but the front main seems like more of a projectI have not worked on the 2.8 so may not be much help. You probably had cork gaskets. I like the blue Fel Pro gaskets if you can get them for the 2.8. I have had bad leaks from the valve cover gaskets.
Honestly im just glad how much space i have to work with. I typically “work” on newer cars so looking at this isnt a big deal. Its not like i have to remove a whole intake assembly to replace something or pull a cv axleI have not worked on the 2.8 so may not be much help. You probably had cork gaskets. I like the blue Fel Pro gaskets if you can get them for the 2.8. I have had bad leaks from the valve cover gaskets.
