Help with ID of metal pin under driver’s side dash
rangerinthewild
Southeast, USA
Was starting to work under the steering wheel to adjust the auto transmission gear indicator. Anyway … I removed the plastic panel, and then was removing the metal panel under the plastic one, and all of a sudden a metal pin dropped down onto the floor mat.
I have no idea where this pin came from. Everything seems to work - steering, shifting into gear, etc.
Have uploaded a pic of the pin. Any ideas?
The vehicle is a 2001 Ranger XLT. 3.0L. Auto trans.
It's possible that it is left from someone working in the truck previously. However, here is a similar Ford steering column and a few places to look.
Most likely place, the shifter handl pivot. But I would expect big problems if that's not installed.
Next is underneath the column, mear the top. Here...
And here.
Then, 2 more pins near the bottom end of the column.
“It's possible that it is left from someone working in the truck previously.”
Yeah, maybe they lost this one and replaced it. I hope so. Like I said, everything seems to work OK.
I appreciate the pics very much. I’ll take a gander and see what I can find.
