PlumCrazy's 88 SuperCab Build
Most important piece to the puzzle arrived today!
Agree with putting the motor you want in. It is still cheaper then the new trucks and something you can enjoy. I have same truck as you but 4 wheel and V6. Looks great!!!
Well....I fell behind on this project, but it'll back on it soon. Was driving it on the night of 4th of July and the TFI bit the dust on our way home from dinner. Thought it ate another distributor gear, but that was not the case. I haven't had a distributor mounted TFI fail on a 2.3 before, normally just an issue on the V8s in my experience. Drug it on the trailer at 1am after watching fireworks from our prime roadside spot and then let it sit in the driveway in timeout for a few weeks before I diagnosed it.
Picked up a TFI heat sink from an OBS truck and removed a few fins for the Hall effect sensor wires.
I was going to extend the wires and get this mounted up ASAP....but decided to wait until I gut the harness and rearrange it for the PimpX install. Which will hopefully start this fall. I have an 8.8 to build for the car and a frame to patch up on my winter beater first.
Stumbled across a deal on a 3.55 Trac Lok Ranger 8.8 with 10" backing plates....dirt cheap, low miles...but a trashed pinion bearing literally on my way home from work.
Common issue I have had with 8.8s that sit awhile, moisture gets in and small amount of corrosion pits the outer race and eat eats itself alive if you drive it.
Had seals already, but had to steal the bearing and crush sleeve eliminator from my V8 truck parts pile. Had Rip throw it back together for me.
Truck currently has an open 3.73 7.5 so I was pretty stoked to find this unit. I'll have to upgrade the driveshaft to 1330 or 1310 as well, which honestly probably needed for any way with anything over 100hp
LSD rear end is a new addition to my list of add on parts. Id be happy with a 7.5 inch rear with LSD though. can you reuse the stock drive shaft when you put a 8.8 in?
Not on this Ranger. It has a the tiny u-joints (I don't recall what series, but smaller than 1310). I already ditched the giubo and upgraded to 1310 at the transmission. I am hoping I can use the shaft from the carrier bearing back from my STX parts truck. Or.....Ill track down a 98+ one piece shaft and ditch the carrier bearing all together (sometimes an issue on a lowered truck though)
Didn't early trucks use a 1210 joint?
This truck is finally next on the chopping block.
Stopped by Summit and picked up a wideband on our way home from the inlaws in NY, so now I'm ready to get started.
Decided to whip up a jib(?) for the forklift first to make life easier. Seems like the forks are always a hair too short reach where I need.
Made from free drops and scrap
Event Coverage
TRS Merch
