Truckspotters
Sorry @Rick W the only way it could be perfect is if it was full of very good looking females.
Good lard. Now that is what I call "redneck welderish:".
What states 1-10 scale are we using for these very good looking females?
A 10 in Montana is like a 3 in Florida..
On the 1 to 10 scale in prison a 10 Montana/3 Florida is a 20.
The way I see it a Florida 10 is a Hollywood 5.5.
So I think we should use the Hollywood scale.
And the bare minimum allowed should be an 8.5.
Now should we also talk about the crazy scale that goes along with the hotness scale?
I've found that each person has a different tolerance for different amounts of craziness.
And what about the dingy scale?
Or should I say the naive scale?
Fire up your imagination and picture this:
Truckspotters
Flat towing one of these:
Truckspotters
I met this conglomeration on the interstate. Maybe the motorhome was pushing the Jeep? Had a regular towbar setup like what one usually sees used to tow a Jeep behind a motorhome...
And also @Rick W has some competition... found this on FB
Truckspotters
That has got to be one of the most unique ranger's I've ever seen! The winnebago n jeep not so much.
depends on disposable vs long term. Tyrus on Fox says guys will rotate four twos together 8. I’m good with that.
Truckspotters
Truckspotters
I’ve seen this one. I think I’ve seen it on here before. Not only did they shorten it, they narrowed it for the Ranger.
I’ve seen a Mark V that was simply scooped out in the back to make a Lincoln El Camino/ranchero. It was also done very well, looks like showroom.
Truckspotters
Truckspotters
I would say that any modern Jeep (or any brand of vehicle that isn't a full size truck honestly...) could flat tow that Winnebago... Once..) I don't see any Jeep transmission holding up very long though
AJ
Idk about 2s but prior experience has taught me a pair of 5s definitely adds up to 10 AND a renewed sense of joy about life lol.
that old jk engine in that wrangler probably used the last of its life to pull that rv. those are very low powered wrangler motors and barely could pull themselves
3.6 runs alright... but a flat towed RV won't have any brakes unless he had mama back there to try to woe the thing...
That's the I've always done flat towing. Gotta have a trusted co-driver. When you're using a chain, they are your brakes too.
