What did YOU do today?
I thought about doing a sediment/ ball valve set up. the compressor does have a valve at the bottom, and the pipes are all much higher than the compressor. still think I need a ball valve and trap? I would likely put one at the workbench and another at the hose reel if needed.
I drained about a gallon of water out of the compressor itself last fall. never drained it before in 13 years. will be more diligent in doing so going forward..
AJ
AJ
Usually the compressor has one. Then the main line is started at the highest point from there, and slopes down until you get to the end, then have another drain. Best practice, you should have a valve at the bottom of every drop from the main line.
Yes, it's recommended. You'll still get some condensate out there. Heck. I have drains on my drops and I empty them. And I still occasionally see water vapor out the exhaust of my die grinder. Of course, I live in South Carolina, the humidity Capitol of North America.
Make sure you put drains on all the drops and low spots. You don't want water to collect there.
Oops... Everyone already said that...lol.
I love, throwing hand grenades into the middle of all you guys so you can crap all over me.
For my excellent and extensive PVC air delivery system, everything straight and level within 2.2 inches over 5 feet, I have about a half a dozen drain spots, maybe more. I use a T instead of an elbow, with one leg pointing down. I drilled PVC caps, and I put in tire Schrader valves…
I’m putting on my hardhat before I hit send…
This year’s focus is to get first the front of the house, and then the entire property, cleaned up from the years of deferred maintenance when I was sick and hurt.
You have to start somewhere. I already cut back the overgrown bushes, and I started repairing a place on the bay window that got wet and a little rotten. I’m going to spread the turf builder stuff around and over seed with some fresh grass seed.
But after finding out I’m not allowed to use my right hand until after the surgery, I was sitting here going stir crazy. I thought my head was going to pop. Lincoln‘s too.
So we hopped in the Missing Linc and went the mile down the road and got some pansies for around the mailbox and such. I know, I know, it’s like putting lipstick on a pig, But don’t worry, I’m not taking any more chances with my hand
When I moved here, there was a teenage boy next-door who loved all my cars and craziness. I’d give them a few dollars here and there and he’d wash the cars and do whatever. Well, he’s like 40 years old now and he’s not so interested in that anymore.
A few months ago, a new family moved in about four houses down, and they have a young teenage slave - er - boy. I’m guessing he’s like 13 or 14. He loves the trucks and the Lincolns, so I drafted him to put my pansies in. We got a few in and then it started raining. It’s going to be a great relationship.
hmmm I like the idea of a shrader valve at the end... my luck would be a large piece of debris/ rust would get caught and it wouldn't close... which while not the end of the world would make me have to get the Shrader valve tool and depressurize the the system to clean it out...
at work (when I worked at a factory) i saw actual sediment bowl attached to a valve similar to the one i have hooked up to the reel that you can undo a drain nut at the bottom of the bowl to blast out the crud. the fancier ones had an automatic setup as soon as the bowl filled, they would automatically open, but those were on the main plant air lines which I have no need for a 1 or 2 inch air line lol. there is that feature in the pressure valve I have attached to the reel. That valve is already at the lowest point of the line (when I put it in) for the hose side. the best part is you can see the water/ condensate fill up. in the last 13 years, that bowl never got water in it where the tank itself did. But the last house did not have near as much pipe as I am putting in this one and i manually hooked up a soft line to the workbenches if I wanted air to them.
If this a good setup, I may just get another one of these valves and hook it up just before and below the workbench pipe on the other side of the garage.
so to the masses (lobbing another grenade back @Rick W if nothing else to put a small dent in his helmet, would this be an acceptable clear out point? attaching close up pics of the valve system in question
AJ
Water/Oil separation is exactly what those are made for. We try to keep one on every air-powered fixture at work.
AJView attachment 124658View attachment 124659
One would think that the moisture would blow to the end of the line as the air flows through the line, but that’s not always correct. It condenses out of the air throughout the whole system. So when you do your piping, just have a little tiny bit of fall to the low spots, and put the drain points there.
If you’re using iron pipe, drill a hole in the drip leg cap, and use one of the Schrader valves like you see on a bigger truck, the ones you have to tighten up with a nut, not the cheap ones you just pop in. Worst that would happen is you’d have to shut your air off, take the cap off and clean it out, and put it back together. I’d be amazed if that happens once every 10 years.
When I put in my drip legs, I always make them on the long side when using PVC. If one were to get really messed up, I could just cut it off and glue a new one on in its place. If that were ever to happen repeatedly, before I used up the last bit, I’d put a coupling on and another longer Drip like. BTW, in a dozen or 15 PVC systems I’ve had or I’ve worked with over the years, I can’t remember replacing even one.
I run my air at about 80 or 90 psi max, and I have it on a mechanical count down timer switch. Compressed air is a money and energy suck. I rarely use it for more than a few hours at a time and I don’t let it run what I’m not using it. So if one of my Schrader valves gets messed up, I can just let the pressure off, take the Schrader valve guts out, and pressure up the system to hopefully blow out whatever. I can also use my little portable compressor and just put it on the Schrader valve as if I was inflating a tire and blow whatever back into the system. That’s far from ideal, but I’m not having to depend on this thing like a lot of you guys. And beyond my system, when I finally get it finished, I have two or 300 feet of airline, and I live on a half acre property, so I would never be stuck without air anywhere. Ditto for my neighbors.
Answer afterthought, if your pipe is clean when you’re putting it in, and you put a cheese cloth over the intake of your compressor to act as an air filter, I don’t know where you’d get any debris from anyway, so it’s mostly the moisture you’re dealing with
My two cents, hope it helps
EDIT: water is never good, so you want to try to get it out. But unless you’re doing something pretty sensitive, like compressing breathing air, a little bit of oil passing through the system shouldn’t hurt anything.
You know guys, we’re getting to know each other at this point. Stop beating around the bush. If you guys don’t like the PVC idea, just tell me!
I have no problem with anyone else using PVC… I like to watch things blow up.
Hmmm, that gave me a thought. I ran natural gas out to the garage when I put the furnace in. Yes, I did it in iron pipe.
But now I’m wondering if I could just pipe it into my air system and save the electric on the air compressor…
Robot operating and programming class. I rarely write or modify the robot movement programs. We have a separate team for that. So, good review. Maybe I’ll sneak a picture later.
That sounds like a great idea.
Disclaimer - Again… I like to watch things blow up.
Got the mower ready for warm weather action today. Blower off, fresh blades and a coat of graphite on the underside of the deck. Needs a bath.
Ran the power equipment that has fuel kept in them all the time for their quarterly, 20 minute (minimum) run while I was cleaning the inside of the windows on the 2011. I also burned sticks that weren't in good enough condition to be used as kindling for starting camp fires or fires in the fire ring in the back yard.
