- Oct 1, 2024
- Arizona
- State - Country
- AZ - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- 4" Super Lift
- Tire Size
- 33"
Hello,
I've been having some trouble with my Ranger for a little bit now. I have a 2004 4.0L V6 FX4 Off Road XLT Ranger. When I am driving and only when my speed is 75 mph or above the ABS light and Brake light will sometimes come on, this does not happen every time I exceed 75 mph as it is inconsistent but it has been inconsistently happening for a little bit now and I want to fix it. It appears to be a soft code as when I turn the truck off, the ABS and Brake light turn off on the dash. Below is a photo of the codes I was able to get read when the lights came on:
I checked each sensor making sure they were in tack and they were (I inspected the outside but I did not take the bolts off and completely pull them out), I also checked the wiring as far as I could until they merged with the engine wiring harness and it all seems fine as well. I cleaned my battery terminals from corrosion thinking maybe it was possibly a grounding issue and that did not fix the issue. The odds of all 3 sensors going bad at once I feel are slim to none and am not sure where to go from here as to what to check/replace/repair. I believe I have listed everything I have tried and all the details about what is happening. Any help would be greatly appreciated. Thank you!
