- Oct 19, 2024
- Louisiana
- 3.0L
Hello all!
I have been working on my dad's Ranger on and off for a month. It was in bad shape when he got it.
Insanity bad shake at startup and would never go away. Shaking would increase from 50mph and decrease at 60. AC doesn't work, coolant temp sensor code won't let the PCM activate the compressor. Slow and sluggish. Finally multiple exhaust leaks at the manifolds.
What has been fixed and replaced:
Sparkplugs
Sparkplug wires
Coil
Injectors (6)
Thermostat
Coolant temp sensor and sender
Camshaft position sensor
Crankshaft position sensor
EGR tube and valve
MAF has been cleaned
Engine mount (driver side)
Heads have been replaced with remans
Dad's Ranger is running much from when he got it due to all the work but there are problems now that I can't figure out:
Truck needs to crank for a few seconds before it will start
Engine shake
2ish misses and no codes from those misfires. Misfires will start when cold but reduce or go away when warmed up. Misfires do return when reving.
I haven't checked the sparkplugs yet to find which cylinders are misfiring. I suspect fuel injectors.
The only code that pops up is for the coolant temp sensor.
I appreciate any suggestions on what my problems are.
Sparkplugs
Sparkplug wires
Coil
Injectors (6)
Thermostat
EGR tube and valve
Engine shake
