eightynine4x4
- Oct 15, 2020
- New York
- 2.9 V6
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
So I’m good to go with my front axle shafts u joints. All 3 are perfectly snug and square and move freely. I’m done one front driveshaft u joint, and have two there remaining.
After that, my entire system is ready to reinstall. This includes the knuckles, which now have new ball joints. Also includes the steering arms/rods.
i just finished installing the inner bearings on the rotors and I’m a little concerned about something…
After installing the seals for those bearings, there is quite a bit of play in the bearings. Like with the rotor sitting flat on table, i can reach in and lift the bearings up 1/8” and let them drop. Is this normal?
I installed the races that came with the SKF bearings. I removed the ones from the rotors that i got. Everything is solid, installed great.
But something feels crazy about having bearings that can slide laterally a little bit along the spindle shaft. Or is it fine?
