- Oct 15, 2020
- New York
- 2.9 V6
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
1989 Ranger 4x4 Manual Locking Hubs
So after a scary incident where my drivers wheel flew off, I’ve gotten motivated and have opened up my wheels and spindles and removed the drivers and passengers axles, leaving just the yoke / small-axle / diff in place still. I’m going to replace what is needed.
The pic below is my drivers axle. Although the recent incident WAS this side, I doubt the condition of the axle end was caused by it. My lugs flew off while I was cruising at like 25-30 mph and my truck dropped a foot onto the rotor and I coasted on the rotor for 20-30 feet. I don’t see why this would put unusual pressure on the axle shaft inside the spindle. Both hubs were unlocked and the manual transfer case was not in 4x4. The rotor got chiseled and the hub fell off and was crushed by a passing car but that’s it.
Or maybe the angle somehow did this?
Anyways, I’m in the process of putting new U-Joints on the front, which is when I finally noticed this..
First two are drivers side, third is passenger.
What is this wear and tear from, if not this incident? Just extreme positioning while off-road 4 wheeling, causing this axle shaft to lean into the spindle a ton?
And do I need to replace it? I was about to order one but then realized the spindle covers the exact section that is damaged so that area of splines isn’t needed anyways. Obviously the small edge of the spindle lines up perfectly where the splines first disappear.
