- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
86 B2 2.9L
Cold it wont do it.
Warmed up, and just a slight tip in of the gas pedal, itll start surging bad. Doesnt do it at idle, nor above that point.
I can literally make it do it at will by holding the throttle at the right point, and unplugging/plugging in TPS.
I replaced the TPS...no change.
I should add that if i hold it long enough (about 15 seconds) and allow it to surge it straightens out.
Its just annoying cause its right about where you hold the throttle to let up on the clutch...so take offs are jerky unless you go a bit harder on the throttle
Any ideas?
Cold it wont do it.
Any ideas?
