calinva
Looking for both fuel lines that go from Fuel pump to the filter w/fittings 2011 Ranger XLT 4.0 extended cab or info on parts to make them.
I've seen those and if I can't get the actual lines I'll have to go that route. Besides the tool do you know the line sizes ?Ya know if you can't find complete lines... there is a few line repair options.
I bought a Dorman nylon fuel line repair kit a year or two ago. The tool makes short work of pushing fittings into new nylon line. They also sell about any connector you might need.
Looks like the price on the tool went up a good 25% since I bought mine.
Thanks for the link but according to my truck info and Vin. It says it won't fit.Is this it?
7L5Z-9C327-A 7L5Z9C327A - Ford Parts Giant
www.fordpartsgiant.com
In all cases I have run into, nylon tubing goes by OD.The early Rangers had a mix of 3/8 and 5/16... the bigger size used for fuel return the smaller for the pressurized side.
I haven't had to fix the later model Rangers I've owned... so I can't say positively. It should be easy enough to put a caliper on the line and subtract for the I.D. to get the right size line.
The reason I just stayed nylon... it plain works... for a long time even in the rust belt.
From what I can find it seems to be 07 thru 2011 but at this point I'm not sure myself.Is 01 and 11 comparable?
