- Nov 15, 2024
- Age
- 65
- Brookhaven
- State - Country
- MS - USA
- Other
- 2021 Bronco Badlands 2 Door
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
- Manual
- Total Lift
- Skyjacker Leveling Coils
- Tire Size
- 31x10.5x15
So the last step of installing an OEM RAP module is getting this light to work when system is armed. I first thought that the bulb was bad, so I got another one the JY. Didn't work. I have continuity from the module to the cluster connector. I removed the bulb and jumpered it to the pin on the connector. It blinks as it should. I don't see any breaks in the tracers on the circuit board but I still can't get a connection when everything is connected. I lightly cleaned the board with rubbing alcohol and a toothbrush. All other functions of the cluster work fine. Any advice?
