- Sep 14, 2020
- Saskatchewan
- 4.0L
- Tire Size
- 31x10.5x15
- My credo
- Saskatchewan...hard to spell...easy to draw
Have you checked this guys channel?
I have probably put 3000 miles on my M62 pushing 5-7psi. Over 1000 miles of that being VERY abusive offroading. I will say, heat is a huge problem. Truck runs 210* and climbs to 230* really quick with any abuse. I have tried everything from no thermostat, to 3/4" orifice, to 160*, 180* and 195*. I have tried E-Fans, stock plastic tank rad and now a full aluminum rad with a factory mech fan with "severe duty" clutch. I used to run an oil cooler through automatic trans cooler portion of the rad too.
Awesome! Thanks for the feedback. Iwill be running the OHV, but Iappreciate knowing the reliability.I do not have experience with the GM version of the M90, but I have over 10k miles on my Moddbox conversion on the 09, and I had a 03 Ranger that I put the rpcaster supercharger kit on and drove it at least 50k miles before selling it. Both of those kits use the T-Bird M90. In both cases I changed out the input shaft seals and the drive coupler, and put in new oil in the blower. Those blowers are very reliable and last for a very long time, and I have had zero issues with either of them.
Thanks for the info. I have read and heard that heat is an issue. Iam going to run an air intercooler in mine most likely to try and help. I may also run hood vents when I put on my fiberglass hood.I have probably put 3000 miles on my M62 pushing 5-7psi. Over 1000 miles of that being VERY abusive offroading. I will say, heat is a huge problem. Truck runs 210* and climbs to 230* really quick with any abuse. I have tried everything from no thermostat, to 3/4" orifice, to 160*, 180* and 195*. I have tried E-Fans, stock plastic tank rad and now a full aluminum rad with a factory mech fan with "severe duty" clutch. I used to run an oil cooler through automatic trans cooler portion of the rad too.
Currently the factory fan, shroud and no oil cooler is doing best. I will likely add a remotely mounted external oil cooler with an E-fan later. My next build will have no AC and potentially a rear mounted radiator.
id assume it already has bigger injectors and throttle body, bit what about engine management
I thought I'd post an update. You can follow by build on Youtube: Manscout Raptor Ranger Build
The rotors are in great condition. That is the correct boost level. Keep in mind:That seems too low of boost for the size pulley you have. What did the rotors look like on that blower before you installed it?
Hi Jim I'm new here as a member and I just finished doing the Moddbox conversion. How do I post here, I have been reading here for a few years great siite.Hello all,
I know this is an issue that comes up from time to time. I also know it's been done. However, we don't have a page in the tech library with any information to help people out. Instead they're stuck surfing the forum.
I'd like to get people to post all the info (including photos) they have on supercharging a 4.0L engine. If you've actually done it and can right something up, that would be awesome. In the meantime, we'll put all the facts on one page and hopefully when someone does it they can submit a write up for us.
Let's see what you have/know:
Thanks!
