- Nov 13, 2018
- Canaan
- State - Country
- NH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
Once you have the convertor nuts off, push the studs through the flex plate as far as you can- they won't go all the way through- and pull the engine just like you would with a manual trans. If the trans is going to stay, now's the time to replace the front seal. The convertor has a drain plug so you won't get an ATF shower when you pull it.
