- Feb 15, 2020
- Southern maine
- State - Country
- ME - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
- Total Drop
- Shackle flip
- Tire Size
- 235/60/15
- My credo
- Its probably better to be self deprecating than self defecating.
..But then again we encounter emergencies in which we must make split second decisions. We slam on the brakes and swerve.
...But the question remains, what is the right balance between front and back?
There literally is no answer to your question.
Ambient temp, type of surface, type of tire, tire pressure, spring rates, damping rates.. all going to have effect on what the ideal bar balance is. In the case of a pickup which could be empty OR could have 1000lbs in the bed.. it's more complicated.. do you set things up for this 'max safety' with a load in the bed.. or unloaded? There will be a difference, and there must be a compromise.
Compounding the problem is the inherent subjectivity of what 'feels' best.. and the question of what kind of setup is the driver most proficient driving? you might HATE how a rear bar feels.. never know..
adding a rear bar or adding a bigger rear bar will reduce understeer....
....perhaps a little understeer is gonna be the safest option in your next 'slam on brakes and swerve' situation... you never know... sudden unexpected oversteer is literally just as dangerous.
Anecdotally... what's the class of rangers & s10s that run the smaller circle tracks called? Sport truck?
Man.... those trucks are set up to handle as best as they possibly can for the most part.... and every single one STILL manages to flip over 4x throughout the season
