Universal Mini aftermarket supercharger đź‘€
Bear in the woods
Corinth Ms
30”
fits 2.0-3.5 sounds s interesting. Anyone tried anything like it ? Any info? says it improves power by 30% …. Doubtfull…. But even 15% would be a noticeable difference
Try it out!
works both directions???
from a positive displacement unit?
hey Jethro, hold my beer, I need more power in reverse so I'm a gonna switch some plumin' around
I have a SC14 on the shelf.
Badass unit.
They ain't mini, tho.
It would sure be neat if you had something cool to put it on...
Moddbox kit for the SOHC gets delivered the 13th...
Now if I actually get the time within the next 6 months to put it on is a different story...
so is the power increase good with them. And what other things need to be done … like bigger injectors, hotter spark.. exhaust .
I'd imagine all the usual boosty stuff.. colder plugs, more fuel, some sort of tuning
These are 2 lobed rotor devices with no twist in the rotor. The displacement is pretty similar to the M90. Since the M90 has 3 lobed rotors with twist, the M90 is much smoother to drive, and has much less pulsation of output. All of which makes the M90 a significantly better choice, imho.
and can still be found in the junkyard, if i remember right /\
Eaton M62/M90 Supercharger Family
Where to find it: 1994-2007 GM cars, 1989-95 Ford Thunderbird Super Coupes
Boost potential: Medium
Dimensions (late-90s M90): 21-1/2″ long, 9″ wide, 5″ tall
Junkyard Extraction Hassle Factor: Low
Awesomeness Factor: High
and you can change the pulley and bearing nose cone to make it shorter or longer if you find one that is opposite of what you need.
